HP 14-ac180nd SKITTL10 - 6050A2730201-MB-A01
Discussion in 'BIOS/UEFI' started by technical, Mar 6, 2018.
    Similar Threads - ac180nd SKITTL10 6050A2730201 Forum Date
    HP 14g-ad005tx SKITTL10-6050A2730001-MB-A01 BIOS/UEFI Oct 10, 2017
    SKITTL10-6050A2730601-MB-A01 BIOS BIOS/UEFI Nov 5, 2016
  3. menoscero
    menoscero Well-Known Member
    hala tienes el esquemático o el boardview
    current Unavailable
  5. ct lab
    ct lab Well-Known Member
    sir please give skittl10-6050a273000-mb-ao1 bios bin
  7. dnalaptop
    dnalaptop Well-Known Member
    I NEED IC CODE / SERI IC U6600
  8. bruce
    bruce Well-Known Member
    PLEASE KINDLY CLEAR ME THIS FILE I REPLACED CPU
    • OLD.bin
      8 MB
      13
  10. 43ifix
    43ifix New Member
    it gives error whiles writing or programming. please check if you can fix it or get me another to try.
    thanks sir
    you need check tool and chip bios and connect, can not file bios
  12. 43ifix
    43ifix New Member
    i changed tool and bios chip but still same issue.
    send one photo error i check
  14. 43ifix
    43ifix New Member
    this are the images form the 2 tool programmer
    not related to the bios file, you can try one bios other any and check result...
  16. 43ifix
    43ifix New Member
    i
    i try different bios file and is successful
    do you think the problem is from the BIOS file?
    HP TPN-L119 6050a2730201-mb-a01
