Dear technicians and engineers First of all, merry Christmas, I need to fix a mid 2011 Imac A1311 with MLB 820-3126-A It,s my first time with imacs I heard that is very common SMC failures and Ati radeon hd6750m gpu failures MLB is dead no start no chime only high speed fans so I think is a smc failure, could you help me to start checking mlb? Now I have all the info, schematics and brd files but It will be great with a first steps tips in mlb check, I tested psu voltages and are ok Thanks in advance Best regards
Nobody can say exactly, all needs to try. You can't fix it with just a few questions. Let's start testing from the most basic components....
SMC is can not check, you need try one BIOS new. you only can reset SMC where mac have display or ignore it if the Mac has no display...
SMS System Management Controller" you can buy chip new and change where want. example: Please check right name above motherboard for you and buy right. https://ru.aliexpress.com/item/F2117LP20H-F2117LP-BGA-SMC-chip/32393640108.html
