Asus N56VM R2.0
Discussion in 'Schematics' started by technical, Sep 29, 2014.
Asus N56VM R2.0 5 5 2votes
5/5, 2 votes
  1. 01ifix
    :cheers::cheers:(y)(y)
    I see normal bios, I do not know what you are talking about....
  3. 02ifix
    yso you dont know .. give you examples of you WRITING on a thread BIOS blabla in this case N56VM ... then you chek on hex editor and you see N56VZ for ex . what you dont understand ? im not saying that they are bad bios , im only saying you need to ORGANIZE the THREADS , you can't put a bios for a model that is not for that model !! its making people wasting time and resources , so please double chek the bios you put and make sure ITS FOR THE CORRECT MODELS ! :) thank you
  4. 02ifix
    in this case the bios i need i found on another thread (of the lots of the thread created for a single model (that i dont understand why as well ) and the correct bios for the ASUS N56VM rev 2.3 with GPU n13p-gl-a1 and the bios on the site its the version 214 .. so here it is A CORRECT BIOS with CLEAN ME if anyone need !!
  5. cdwayne foremost
    cdwayne foremost Well-Known Member
Similar Threads - N56VM Forum Date
Asus Asus N56VM BIOS/UEFI May 30, 2014
Asus Asus N56VM BIOS BIOS/UEFI May 29, 2014
