Dell Dell Alienware 17 Dell VAS00 LA-9331P HM87
Discussion in 'Schematics' started by 04ifix, Jun 8, 2014.
Dell Dell Alienware 17 Dell VAS00 LA-9331P HM87 5 5 1votes
  1. techar
    techar Well-Known Member
    i did it , thanks
  2. techar
    can you help me to remove bios password
  3. techar
    how to remove password
    is it using hex editor?
    dell can not remove via hex.
  5. Siroos_tz
    Siroos_tz Well-Known Member
    Hi,
    Do you have U2 IC dump file for this Dell model? The IC is 25Q80BV. I think this IC controls Lid sensor, GPIO and FlashRom. Thanks
    This ROM is not related to the system BIOS, what is the fault of the laptop?
  7. Siroos_tz
    Laptop is not switching on at all. I have +5VALW, +3VALW and +3VLP but there isn't +3V_PCH. It means I don't have voltage on pin 1 and 8 on UH14 too. I am using RT809H, but I can't programme IO KB9012 offline or as ISP. Gives me error. I tried a brand new IO IC which result is the same. No luck for programming it. I think I have bad IO or bad PCH chipset.
    have support Programming KB9012, you need Programming doen it
Similar Threads - Dell Alienware Dell Forum Date
BIOS PC Dell Alienware Area 51 R5 BIOS/UEFI Apr 2, 2018
BIOS PC Dell Alienware Area-51 R4 BIOS/UEFI Apr 2, 2018
BIOS PC Dell Alienware Aurora R3 BIOS/UEFI Apr 2, 2018
BIOS PC Dell Alienware Aurora R6 BIOS IPKBL-SC BIOS/UEFI Apr 2, 2018
BIOS PC Dell Alienware Aurora R7 IPCFL-SC BIOS/UEFI Apr 2, 2018
