BIOS ef10mix
Discussion in 'BIOS/UEFI' started by technical, May 19, 2016.
BIOS ef10mix 5 5 1votes
    BIOS ef10mix
    EF10MIX netbook 2015
    Schematic HP CLASSMATE PC - ECS EF10MIX
    Intel CMPC2013 EF10MIX Schematics
    Revision : V01
    Similar Threads - BIOS ef10mix Forum Date
  3. medalist
    medalist Well-Known Member
    plzz this bios not work plzz send another bios
    U22-CORADIR
    Clear me
    ECS Ef10mix
    HP CLASSMATE
  6. rossmery gonzales
    rossmery gonzales Well-Known Member
    le grabe los bios pero sigue pidiendo serial ...
    sugerencia
    send one photo problem.
  8. rossmery gonzales
    hqdefault.
    photo download from google ?
    old bios error what? send i check
  10. rossmery gonzales
    es que ese es el error !!
    tienes la solucion por que ya le grabe bios !
    it can recover where reboot or it can skip..
    If you do not receive a notification when starting, you can ignore it
  12. rossmery gonzales
    no deja ingresar mas alla del codigo de activacion y tampoco se puede omitir !
