Acer Swift SF314-52G CA4DB_10L
Discussion in 'BIOS/UEFI' started by technical, May 28, 2017.
Acer Swift SF314-52G CA4DB_10L 5 5 1votes
    BIOS
    Acer SWIFT 3 (SF314-51) CA4DB_10L REV 2.2.BIN
    CA4DB_10L REV 2.0
    Similar Threads - Acer Swift SF314 Forum Date
    Acer Swift SF314-52 bios HE4EA REV 2.0 BIOS/UEFI May 28, 2017
    Acer Swift SF314-51 BIOS/UEFI Sep 17, 2016
    Acer Swift SF514-52T N17W3 17809-1M BIOS/UEFI Apr 9, 2019
    Acer-Gateway Acer Swift 3 (HE4EA motherboard) need shcematic or board view Schematics Sep 30, 2018
    Acer Swift SF113-31 BIOS AS3EA_UMA REV 2.1 BIOS/UEFI May 28, 2017
  3. Peperoni23
    Peperoni23 New Member
    no luck for me . issue automatic on and off . no display in this bin, that is my old bios orig pls clean
    Clear me Acer Swift.bin
  5. Budavary Tamas
    Budavary Tamas New Member
    I need boardview and/or schematic.
    Acer Swift SF314-51 CA4DB_10L MAIN BOARD REV:2.2
  7. levi
    levi Well-Known Member
    need ec bin file
    yes, update on top.
  9. 13ifix
    13ifix Moderator
    brother check this bios also
    Acer Swift SF314-52G i see BIOS 8MB, sure right mode ? send add motherboard code i check.
  11. 13ifix
    13ifix Moderator
  13. 13ifix
    13ifix Moderator
    this bios is not ok
    check hardware.
  15. 13ifix
    13ifix Moderator
    please one time you check my bios
    final :(
  17. RGA Ltda
    RGA Ltda New Member
    por favor me puede enviar archivo bios CA4DB_10L REV:2.0
    same on top
  19. RGA Ltda
    RGA Ltda New Member
    [QUOTE = "ThienBui, post: 112170, miembro: 6"] igual en la parte superior [/ QUOTE]
    todas las descargas dicen que son rev 2.2, me sirve de todas formas reprogramar la placa madre rev 2.0 ?
    same 2.x you
  21. RGA Ltda
    RGA Ltda New Member
    necesito reprogramar placa madre rev 2.0 y la que se muestra es rev 2.2, la pregunta es, me sirve el archivo para reprogramar placa madre rev 2.0 ?
