HP Probook 470 G3 -"Your system is not fully configured - contact your hp customer support"
Discussion in 'Computer Hardware Repair' started by oliviu50, Jun 30, 2018.
    wow, problem this need Programming full BIOS,
    I think you need to bring the device to a repair shop for BIOS programming support.
  2. fmunier
    fmunier Well-Known Member
    I have never done that, but I am a computer repairer. can you explain to me ?
    You need to program a full BIOS for full laptop communication, BIOS update does not have any info
  4. fmunier
    Ok, I understand that, but don't know how to do.
    Is there any utility?
    How can I do that?
  6. fmunier
    The file you send me is to use with one of this tools?
  7. fmunier
    Ok, to do that I need to desoldering the chip.
    You think there is no solution for me?
    It is just a new motherboard, not fully configured.
    I normaly just have to finish configuration correctly.
    you can try tool this use version new latest
    https://vinafix.com/threads/series-number-hp-hp-dmi-nbdmifit-and-wndmifit.9005/
    But not sure because some new models are not supported
  9. fmunier
    OK
    Solved with BiosConfigUtility
  10. ikapitale
    ikapitale New Member
    HP ProBook 470 G3 bios plz
  11. ikapitale
    plz tienbui bios from probook 470 g3 motherboard da0x63mb6f0 rev f
Similar Threads - Probook system fully Forum Date
