Hello friends, I need to cut the bios attached from 16mb to match 8mb. Can you help me? I can not upload the 16mb bios, does anyone help me?
Recibo una pantalla negra con las biografías de ese enlace. Adjunté 16mb bios, que quiero convertir al primer archivo que adjunté.
As I read, this model only has bios of 8mb, in the official website there is only the one of 16mb that coincides in most part with that of 8mb. Asking several colleagues, they concluded that it is necessary to cut up to 8mb. And that's when my problem begins I do not want to give the equipment for not repaired. Again, I thank you for the speed: yum
check chip above motherboard 8MB (Q64) or 16MB (Q128). or send photo chip i help check. Note: Please not check size from Asus.com it only is bios update.
he chip is '' Q64 '' 8mb. With the bios link that you sent me, I did not get the team to give an image. This repair hahahahaha is causing me headache
For programming use REVELPROG IS. Then I change the SPI chip and comment. Let's see if we can stop solving the issue!
