HP ProBook 640 G2 CIRCUS-6050A2723701-MB-A02
Discussion in 'BIOS/UEFI' started by technical, Aug 18, 2016.
HP ProBook 640 G2 CIRCUS-6050A2723701-MB-A02 5 5 1votes
  1. Lenzy61
    Lenzy61 New Member
    It has been dificult attaching my locked bin file. I can not see where to send it
    • Sad Sad x 1
  3. Lenzy61
    Lenzy61 New Member
    Please send a clear me bios for hp probook 640 g2. password locked
  5. vladzio
    vladzio Well-Known Member
    I bought tools to remove the password, but the revision message has no serial numbers. Laptop HP650 g1. Why the problem?
    It will automatically recover after a while of restarting. You have it wait check ?
  7. vladzio
    Yes, but serial numbers are not tightening:(
    send the bios file check i do you do it as instructed, and photo..
    inbox here i check
    Conversations 0
  9. vladzio
    my files
    • Love Love x 1
    all ok, make video display no serial i check.
  11. vladzio
    video display
    Is this not the original bios of the machine?
    you can returm old have password and check ?
  13. vladzio
    the original bios so, the password is not forgotten
    i think you unlock not right bios origin.
    try it.
  15. vladzio
    this works thank you! I will deal with my dump
  16. b4tech
    b4tech Well-Known Member
    HP G640 G2
    clean me
    power on no display
    fan over rpm
  18. Ninton
    Ninton New Member
    sir please make a fresh bios
    here is file bios error, you need Programming one bios new or check tool backup for you.
  20. Ninton
    Ninton New Member
    sir please make a fresh bios this bios is in restating issue
Similar Threads - ProBook CIRCUS 6050A2723701 Forum Date
Hp Probook 640 g2 Circus 6050a2733701-mb-a02 BIOS/UEFI Nov 26, 2018
