P24JPVSP datasheet or how to read
Discussion in 'Computer Hardware Repair' started by bisketti, Jun 5, 2019.
  1. bisketti
    bisketti Well-Known Member
    I would like to be able to read the contents of this tpm any pointers appreciated.
    Similar Threads - P24JPVSP datasheet read Forum Date
    KB394OQ datasheet Schematics May 20, 2019
    LV50287 DATASHEET Schematics Jan 4, 2019
    LV5075A DATASHEET Schematics Jan 4, 2019
    NEED DATASHEET BQ727 Schematics Nov 17, 2017
    Schematics PC NEED DATASHEET TPS51624 Schematics Jun 29, 2017
  3. 41ifix
    41ifix Well-Known Member
    Through cables directly to the programmer?
  4. bisketti
    I was hoping for a bit more technical answers, of course using a programmer. What programmer to use and which pins to connect?.
  5. 41ifix
    Personally, I am now using Revel Prog IS, but the price is a bit high (approximately $ 157).
    To solder the pins and connect them to the programmer, follow the pattern -> Pin 1 with pin 1 and so on.
    You can try the EZP2010 programmer, which is quite cheap, approximately $ 20.
