HP Main Board Model R62 - DAOR62MB6E1
Discussion in 'Computer Hardware Repair' started by Rui Fortunato, May 28, 2019.
  1. Rui Fortunato
    Rui Fortunato Well-Known Member
    Hi please I need your help.
    This Main Board has one resistor " on fire" (R499) and I can not find the component that is doing this.
    Have you this situation before?
    I alredi change the resistor, but when the adaptor is connected the resistor was burned like a fuse!!!
    Please help
    Regards
    Similar Threads - Main Board Model Forum Date
    Clevo-Axio LANIX NEURON N H34Y MAIN BOARD UMA rev 2.3 BIOS/UEFI May 12, 2019
    Schematics PC FOXCONN S04-915S04-MAINBOARD-A-HW-SCH-061404 Schematics Apr 14, 2019
    SAMSUNG LE40M87BD Chassis (Main Board) BN41-00813E ELECTRONIC DEVICE Apr 12, 2019
    TMX349-G2-M-56D8 A4DB_10L MAIN BOARD 2.2 BIOS/UEFI Mar 26, 2019
  3. 41ifix
    41ifix Well-Known Member
    Remove the resistance to separate the circuit. Once removed it measures in diode mode (red terminal in GND and black terminal in both points of the removed R). You tell me the measurement values that it gives you.
    use schematic and boardview here
    https://vinafix.com/threads/quanta-r62-hp-pavillon-15-daor62mb6e0.8463/
  5. Rui Fortunato
    Hi E1LM
    Thank you for your reply.
    The values is 2.262V and 0.0V (please check the attached picture)
  6. 41ifix
    This case is common in this model. You must replace KBC (U13) and, once replaced, replace R (R499).
    You already tell me how the repair was.
  7. Rui Fortunato
    I already replaced the Super I/O (U13). maybe is damaged, I wil replace again and reply ASAP.
  8. 41ifix
    Check that the KBC I / O has the same revision. Otherwise, it can cause a worse evil. I hope response!
  9. 41ifix
    Something new?
  10. Rui Fortunato
    No...I´m still whating for new Super I/O
  11. Rui Fortunato
    Hello Friends,
    With new Super I/O and new resistor but the problem is the same. The resistor R499 continue "on fire"
    Would you please send the Boardview?
  13. 41ifix
    The pin in the center of the connector is fine?
  14. Rui Fortunato
    Please, which connector?
  15. 41ifix
    DC power connector. The center pin must have an insulation plastic. That's why the fault starts.
