HP-Compaq PROBOOK 6550B 6050A2326701 DIS 6050A2326601 UMA
Discussion in 'Schematics' started by 15ifix, Mar 13, 2014.
HP-Compaq PROBOOK 6550B 6050A2326701 DIS 6050A2326601 UMA 4.7 5 3votes
4.7/5, 3 votes
  2. wally84
    wally84 New Member
    Hello, Can you please unpass my dump? Or can you help it with me, whitch reagion i need to clear.. Thank you.
  4. wally84
    wally84 New Member
    Thank you, but still ask me the admin (blank) pass. Now i can enter to tha bios, but can not reset the security settings, to reset the tpm. What should i do?
    make one video problem i check
  6. 01ifix
    try this
  7. 03ifix
    I think show guest user right? default then remove all error
    • Wow Wow x 1
  8. wally84
    wally84 New Member
    I flashed yours, only charging led blinking when i connect DC power. :(
  9. 03ifix
    Try this get default if show guest user..
  10. wally84
    wally84 New Member
    No guest user. Locked every user in your bios, and boot up speed is really slow.
    I do not understand what problem you are asking?
Similar Threads - PROBOOK 6550B 6050A2326701 Forum Date
