ROG GL702VM (7th Gen Intel Core) BIOS Processor Intel® Core™ i7 7700HQ Processor, Intel® Core™ i5 7300HQ Processor, Operating System Windows 10 Home Memory 32 GB DDR4 2400MHz SDRAM 2 x SO-DIMM socket Display 17.3" (16:9) LED backlit FHD (1920x1080) 75Hz Anti-Glare Panel with 72% NTSC with G-Sync 17.3" (16:9) LED backlit FHD (1920x1080) 120Hz Glare Panel with 72% NTSC with G-Sync With WideView Technology Graphic NVIDIA GeForce GTX 1060 , with 6GB GDDR5 VRAM Storage Hard Drives: 1TB 7200RPM SATA HDD Solid State Drives: 128GB SATA3 SSD Solid State Drives: 256GB SATA3 SSD Keyboard Chicklet keyboard with isolated Num key Illuminated Chiclet Keyboard Card Reader Multi-format card reader WebCam HD Web Camera Networking Integrated 802.11 AC Interface 1 x COMBO audio jack 1 x USB 3.1 TYPE C port(s) 3 x USB 3.0 port(s) 1 x RJ45 LAN Jack for LAN insert 1 x HDMI 1 x mini Display Port 1 x Thunderbolt port 1 x SD card reader Audio ASUS Sonic Studio Battery 4 Cells 76 Whrs Battery Power Adapter Plug Type :ø5.5 (mm) Output : 19.5 V DC, 9.23 A, 180 W Dimensions 415 x 280 x 22 ~24 mm (WxDxH) Weight 2.7 kg Certificates UL, TUV, CCC
Hi ThienBui... do you have this dump? I don´t have backup file and try the 6th gen dump and doesn´t work in this 7th gen. The mother is GL702VMK Main Board Rev. 2.0.
