Dell DELL E7240 LA-9431P
Discussion in 'BIOS/UEFI' started by technical, Feb 10, 2015.
Dell DELL E7240 LA-9431P 5 5 2votes
5/5, 2 votes
  1. Siroos_tz
    Siroos_tz Well-Known Member
    T
    Thank you very much. I will test it and let you know the result.
  2. Siroos_tz
    Hi,
    Unfortunately, the files you provided don't work. Is there any other trusted dump files?
    Thanks
    old bios error what ?
    send i help check
  4. Siroos_tz
    Here you are the old EC and BIOS files.
    Thank you
    try two bios this.
  6. Siroos_tz
    Thanks. I will update you with the result.
  7. Siroos_tz
    It doesn't work either.
    you need check hardware.
  9. Siroos_tz
    I'm 100% sure the problem is BIOS or EC. I can see the AMP using by power supply. The Amp is not playing between 0.30A and 0.60A very quick which is completely wrong. The other Bios I download yesterday, didn't go over than 0.29A.
    AMP cannot say anything, You won't be able to fix your laptop if you only focus on the BIOS.
  11. Siroos_tz
    Sure, but I know what I'm doing. I already had problem with some of your bios files.
  12. Siroos_tz
    If you see the error while I try to clean the ME region, you will see the BIOS problem. It happens for all of the BIOS I have for this laptop. Mostly downloaded from your website. If you can help, it would be great.
    here
  14. Siroos_tz
    Hi,
    Just an update. I have sorted out with another bios file (not with your bios). I don't need to try the last file you sent and I can't tell you if it's working or not.
    But, thanks for your reply.
    #114 Siroos_tz, Jul 19, 2019
  15. khoai khoe hn
    khoai khoe hn New Member
    nhờ anh clear dùm file này, lên rất chậm
  17. meuva umar
    meuva umar Well-Known Member
    Dear Sir/madam
    need clear this bios
  18. meuva umar
    please clear this bios
    i have send mail Please check
  20. wally84
    wally84 New Member
    Thank you. Now mine turn on, but take too long to show the Dell logo. May i need to clear ME?
    //Edit// Yes, clearing ME region, will solve the slow boot problem. Here is the cleared dump.
    #120 wally84, Aug 3, 2019
Similar Threads - DELL E7240 9431P Forum Date
Thảo luận Dump Bios with a test clip - Dell latitude E7240 Computer Hardware Repair Nov 17, 2016
Dell Latitude E7240X Ultrabook BIOS/UEFI Jun 27, 2016
dell e7240 bios BIOS/UEFI Aug 25, 2015
