Apple iMAC 27 slim A1419-CLN
Discussion in 'BIOS/UEFI' started by technical, Jul 12, 2015.
Apple iMAC 27 slim A1419-CLN 5 5 1votes
    BIOS iMAC 27 slim A1419-CLN
    Similar Threads - iMAC slim A1419 Forum Date
    BIN file for A1418 (EMC 2833) iMac "Core i5" 3.1Ghz 21.5-Inch (4K, Late 2015) BIOS/UEFI May 27, 2022
    APPLE iMac 21.5" A1418 820-01061-A BIOS/UEFI Aug 17, 2019
    BIOS PC bios imac 820-2542-a BIOS/UEFI Aug 16, 2019
    iMAC a1419 EMC3070 820-01134-A BIOS/UEFI Jul 18, 2019
    Need BIN file for A1418 (EMC 2833) iMac "Core i5" 3.1Ghz 21.5-Inch (4K, Late 2015) BIOS/UEFI May 26, 2019
  3. sameer hamdan
    sameer hamdan Well-Known Member
    I CHECKED THES DUMP..I SEE THAT DUMP IS LOCKED
    imac 27 slim a1419-CLN
    Unlock
  5. sameer hamdan
    HI...HOW ARE YOU?
    I CAN UNLOCK ALL APPLE DUMP..THES FILE IS PASSWORD REMOVE..BUT THE ICLOUD AND PIN CODE IS WORK IN THE DUMP
    SO YOU CANT USE IT ..if you need any help..just let me know
    Is there a problem with this file?
  7. sameer hamdan
    yes..there problem ..icloud information is set...FIRM locked is set...COMPUTER NAME IS SET..TRACE IS SET...BOOT MODE LOCKED IS SET
    YOU NEED 5 STEEP FOR REMOVE ALL INFO
  8. sameer hamdan
    AND NEED TO CHANGE 1 LETTER IN SERIAL NUMBER
  9. sameer hamdan
    i unlock the dump..you can compare..
  10. Macfixit
    Macfixit Well-Known Member
    hi i look for A1419 dump off 820-00134 do you have one i pay for it the old dump its broke
  11. Macfixit
    Understand, You need what ?
  13. Macfixit
    hi sorry
    i look for bios dump off imac 27" A1419 board number 820-00134A
    Unavailable bios this, bios old error what ?
  15. Macfixit
    the bios broken total dead i tri to fix but it don't work
    do you have a good bios for that board i pay for it no problem
    Unavailable bios this.
    Wait.. I send to you when I have it.
  17. Macfixit
    let me now and i pay you np
    Pay what? I say BIOS this current Unavailable. :(
  19. sameer hamdan
    ENJOY THE DUMP...i fix it
    motherboard code 820-xxxxx ?
  21. sameer hamdan
    A1419 EMC 2546----MD095LL/A
    i just fix and remove icloud and firm lock
