ASUS ROG GL752VW
Discussion in 'Schematics' started by technical, Apr 11, 2016.
ASUS ROG GL752VW 5 5 1votes
    ASUS ROG GL752VW REV: 2.0
    Boardview (Bitmap)
    ASUS GL752VW REV2.1 W25Q64
    • Angry Angry x 1
    #1 technical, Apr 11, 2016
    Similar Threads - ASUS GL752VW Forum Date
    Asus GL752VW
    Repair guide
    • Angry Angry x 1
  4. xenon998899
    xenon998899 Well-Known Member
    We can have the file bios?
    • Angry Angry x 1
    ASUS GL752VW
    BIOS Version 214
    • Angry Angry x 1
  6. xenon998899
    thank you!
    • Sad Sad x 1
  7. dimpu
    dimpu Well-Known Member
    thank you
    • Angry Angry x 1
  8. xenon998899
    hi,
    We can have this bios in clear me (replacement pch GLHM170 SR2C4)
  9. xenon998899
    Bios clear me problem solved!
    ROG GL752VW_Clear me
  11. xenon998899
    Hi,
    I need help to identify 2 component on motherboard GL752VW rev2.1 fault of shema detailed motherboard that has suffered a water damage (+ 3VS in short circuit) pch / audio codec already replaced the motherboard startup image in External (not internal) and has trouble starting to the button (functional keyboard (reset ok!) Forced to put the finger on RN3002 to start the first time after plugging the power then more problem for on / off with the keyboard
    Screen boarwiew of the components identified
    Thank you for your help
    (Sorry for my mediocre English)
  12. xenon998899
    This is the value of the resistance I need for RN3002 for accuracy thank you
    I do not have a motherboard available, I can not determine the index of this resistor.
    A similar motherboard is needed for comparison.
  14. xenon998899
    Ok an idea about the reference of U4503? I specify that the picture is not the original one because burned so no information readable on the original
    thank you
    Yes, We need a good motherboard to compare.
  16. erdenebat
    erdenebat Well-Known Member
    i need a ASUS ROG GL752VW REV: 2.1 bios
    asus1.
    #15 erdenebat, Apr 22, 2017
    ASUS ROG GL752VW -CPU-I7-960M REV: 2.0
  19. bioshunger
    bioshunger Well-Known Member
    ITE it8995e EC FILE
    GL752VW ECROM
  21. erdenebat
    asus gl752vw boardview
