rework shuttle star sv550A
Discussion in 'Computer Hardware Repair' started by aniello, Apr 2, 2015.
rework shuttle star sv550A 5 5 1votes
  1. aniello
    aniello New Member
    GOOD MONING ARE JUST WRITING YOUR FORUM, I WANTED TO ASK, QUALCUNE MEMBERSHIP HAS EXPERIENCE WITH SHUTTLE REWORK STATION STAR SV550A
    THANKS
    Similar Threads - rework shuttle star Forum Date
    Review CF360T Intelligent Mute BGA Rework Station Computer Hardware Repair Dec 28, 2014
    Review CF260 BGA Rework Station upgrade Computer Hardware Repair Dec 28, 2014
    IRDA SMD & BGA Rework Station T862 manual Computer Hardware Repair Nov 26, 2014
    KID R600 REWORK STATION User Manual Computer Hardware Repair Nov 26, 2014
    RE-8500 BGA Rework Station Manual Computer Hardware Repair Nov 26, 2014
    I do not use sv550a, you want to ask any problems?
    you can clear the problem you're having so we refer.
  4. aniello
    aniello New Member
    Hello thank you very much, you have various problems, the function does not work AUTOPROFILE, hangs a continuation, user profiles already pre-installed on them, but I have the problem that the cards I deventano dark side bottom, someone has the right procedure to build ad hoc profiles with this rework? you also have some more info to use machines to three areas like mine? how can I change the rate,
    thanks
  5. 01ifix
    hii have a shuttle star v360 pc v.3 and works great,
    have you try upgrade the software ?
  6. bkvijaykumar
    bkvijaykumar Well-Known Member
    Hi Sir, I want perfect BGA profile for Intel 4th Gen BGA CPU(Haswell). I need Soldering and Desoldering profiles. 4th Gen Leaded balls Leadfree balls profiles wanted sir. Machine Type: Shuttle Star Sp360c.
  7. bkvijaykumar
    WAITING FOR YOUR REPLY SIR.
  9. aniello
    aniello New Member
    Ciao amico ciò che hanno di temperatura per presa di saldatura CPU i7
    Sandy Bridge-
