Bios fix lỗi 104, 105
Discussion in 'BIOS/UEFI' started by technical, Mar 1, 2014.
Bios fix lỗi 104, 105 5 5 4votes
5/5, 4 votes
    HP G42 G62 G72_INTEL_sp50938_1425F26_no 104-105 v2.zip
    HP G42 G62 G72 INTEL_sp50938_1425F26_no whitelist v2.zip
    • Angry Angry x 1
  2. 31ifix
    31ifix Well-Known Member
    bạn có bios fix loi 104 cho máy cq42-168tu không cho minh với nhé
    • Sad Sad x 1
    HP G62, CQ42-450SA Whitelist removal - sp52604 sp52604_NWL.exe
    ( HP G62_CQ42-450SA Whitelist removal - sp52604 sp52604_NWL.exe )
    • Angry Angry x 1
  4. amrish
    amrish Well-Known Member
    PLS PROVIDE SCHEMATIC BOARD NO.DA0AX1MB6H1 REV:H
  6. phovang146
    phovang146 Well-Known Member
    compaq 515 bios whitelist remove plizz
  7. kythuathobi
    kythuathobi Well-Known Member
    Admin tìm giúp file fix lỗi 104 HP Elitebook 8440p. Thanks
  9. Đào Hưng
    Đào Hưng Well-Known Member
    anh có bios fix wifi của lenovo g470 ko anh
    không có model this.
  11. vuvanhoanhd
    vuvanhoanhd New Member
    Anh có BIOS của HP 8440W ko ạ!
    Bios hả hay bios fix lỗi wifi ?
  13. 09ifix
    09ifix Moderator
    cq61 whitelist please upload
    HP G61, G71 Compaq CQ61, CQ71 AMD_sp48895_363FF15_no whitelist
  15. hongminh4t
    hongminh4t Well-Known Member
    cho em xin file fix lỗi 702 cho máy hp dm4-1060us anh nhé.thank a!
    không có sẵn model này bạn :D
  17. tam tran
    tam tran Well-Known Member
    Ad cho mình xin Bios CQ56 dòng core 2 fix 104 nhé. Thanks.
    không có model này..
  19. vu hai duy
    vu hai duy Well-Known Member
    ad hỗ trợ dùm bios fix 104 hp dv5-1000 mã main daqt6bmb6f0 . thanks
Similar Threads - Bios lỗi Forum Date
Hp 8540p lỗi 104 cần tìm bios whitelist Computer Hardware Repair Nov 26, 2015
Toshiba Xin MOD BIOS TOSHIBA C850 fix lỗi chạy tắt BIOS/UEFI Dec 25, 2014
Toshiba Bios fix lỗi chạy 30s tắt Toshiba L650 (DAOBL...) BIOS/UEFI Sep 26, 2014
Toshiba Bios Toshiba L600 L645 TE2 fix lỗi chạy 30s tắt. BIOS/UEFI Aug 26, 2014
Asus Bios asus UL30JT fix lỗi cpu quá nhiệt BIOS/UEFI Mar 22, 2014
