(IC, IO, Chipset Shared) equivalent
Discussion in 'Computer Hardware Repair' started by 15ifix, Feb 26, 2014.
(IC, IO, Chipset Shared) equivalent 4.7 5 7votes
4.7/5, 7 votes
  1. tytoteo1234
    tytoteo1234 Well-Known Member
    npce 885p có sài chung dc với npce 985p ko ad
    chưa test :D
    IO replacement
    Winbond I / O only sub-models, and F = G
    W83627DHG-P == W83627DHG-A
    IT8712F-A IXS == IT8712F-A HXS
    IT8712F-A IXS GB == IT8712F-A HXS GB ( GB is for Gigabyte only.)
    The IT8712F-A GXS can be replaced with non-IXS / HXS. (GB is for Gigabyte)
    IT8702F-A only sub-models, without sub-version, can be interchangeable, part of the motherboard can also be replaced with 8712F-A. (GB is for Gigabyte.)
    IT8712F-S only sub-models, without sub-version, can be interchangeable. GB is for Gigabyte.
    T8716F-S only sub-models, without sub-version, can be interchangeable. GB is for Gigabyte.
    IT8718F-S only sub-models, without sub-version, can be interchangeable. GB is for Gigabyte.
    IT8726F-S only sub-models, without sub-version, can be interchangeable. GB is for Gigabyte.
    IT8705 ** only sub-models, without sub-version, can be interchangeable.
    PC87372 == SMSC 47M172 part of the motherboard can also replace 47m182
    8374LF2-C == 47M182 ==WPCD374LAUFG
    Fintek F71872F == Fintek F71872FG
    Fintek F71882F == Fintek F71882FG
    Fintek F71883F == Fintek F71883FG
    PWM replacement
    ADP3110 == ADP3110K == ADP3418 == ADP3418K
    ISL6612 == RT9600
    APW7062 == ISL6522
    ISL6520 == RT9202
    APW7067 == ISL6549 == RT9259
    APW7120 == RT9214 == FP6321
    APW7060 == ISL6529 == RT9205
    5018MTC == 5019MTC == ADP3180 == ADP3181 ? ADP3168? To be confirmed.
    ADP3168 == ADP3188 part of the motherboard to be confirmed
    ADP3166 == ADP3186 part of the motherboard to be confirmed
    5009M == 3418 (K) == 5007m (boot need to add the diode pin)
    L6917BD == L6916D
    SC2643 == SC2646
    BD-XX == B3-XX
    A1-XX == A2-XX
    Dedicated chip
    IT8282M == ASM8282G == ATPA02G
    Clock chip
    RTM360-111R == ICS950209 == W83194BR-B (some boards can not)
    RTM660-109R == ICS950202 (9 feet different) == ics950220 may run 26
    RTM363-210 == ICS952607EF / CLK865J02FLF (will prompt overclocking error, save CMOS does not light run D1)
    Memory chips
    N2DS12H16CT-5TB ==== K4D261638F TC50 ==== HY5DU281622ET-J
    k4j5532xxx-bc14 ==== hys573235fap-14==k4j5232xxx-bc14==k4j5232xxx-bc12
    HY5PS561621A FP-25===HYB18T256169BF===E2516AB-6E-E===HY5PS561621B FP-25==HY5PS561621A FP-28
    ( With the capacity, with the bit width, the speed of not less than the original value )
    Other chips
    8400GS graphics card above the G86-213-A2 can directly replace the notebook above the 630 series graphics card
    8500GT graphics card above the G86-303-A2 can directly replace the notebook above the G86-703-A2 graphics card
  4. rrun2523
    rrun2523 New Member
    ขอบคุณ
  5. synapsea
    synapsea Well-Known Member
    tps51123 its not compatible with tps51125
  6. Sumoct
    Sumoct New Member
    Các bạn có biết ic thay được cho con max8744ETJ không chỉ mình với!
  7. bioshunger
    bioshunger Well-Known Member
    RICHTEK CODE BOOK
  8. bioshunger
    GPU LIST
    G86-300-A2 --> G86-731-A2 --> G86-730-A2
    G86-302-A2 --> G86-731-A2 --> G86-730-A2
    G86-303-A2 --> G86-731-A2 --> G86-730-A2
    G86-602-A2--> G86-631-A2 --> G86-603-A2, G86-620-A2, G86-630-A2
    G86-603-A2--> G86-631-A2 --> G86-630-A2
    G86-620-A2--> G86-631-A2 --> G86-630-A2
    G86-625-A2--> G86-635-A2 --> G86-630-A2
    G86-630-A2--> G86-631-A2
    G86-631-A2--> G86-631-A2 --> G86-630-A2
    G86-635-A2--> G86-635-A2
    G86-703-A2--> G86-731-A2 --> G86-730-A2
    G86-730-A2--> G86-731-A2 --> G86-730-A2
    G86-731-A2--> G86-731-A2 --> G86-730-A2
    G86-740-A2--> G86-731-A2 --> G86-730-A2
    G86-750-A2--> G86-771-A2 --> G86-770-A2
    G86-770-A2--> G86-771-A2 --> G86-750-A2
    G86-771-A2--> G86-771-A2 --> G86-770-A2
    Nvidia NF-430-N-A3 ----- NF-G430-N-A3
    Nvidia NF-G430-N-A3 ----- NF-G430-N-A3 -- NF-430-N-A3
    Nvidia FX GO 5100 ----- FX GO 5200
    Nvidia FX GO 5150 ----- FX GO 5200
    Nvidia FX GO 5700 ----- FX GO 5700 -- FX GO 5700V
    Nvidia FX GO 5700V ----- FX GO 5700V -- FX GO 5700
    Nvidia NF-SPP100-N-A2 ----- NF-G6100-N-A2
    Nvidia NF-6100-N-A2 ----- NF-G6100-N-A2
    Nvidia NF-G6100-N-A2 ----- NF-G6100-N-A2 -- NF-SPP100-N-A2
    Nvidia NF-G6150-N-A2 ----- NF-G6150-N-A2
    Nvidia GF Go6200-A2 ----- GF-GO6400-A2
    Nvidia GF Go6200-A4 ----- GF-GO6400-A4
    Nvidia GF Go6200-NPB ----- GF-GO6400 NPB
    Nvidia GF-GO6400-A2 ----- GF-GO6400-A2
    Nvidia GF-GO6400-A4 ----- GF-GO6400-A4
    Nvidia GF-GO6400SQ-N-A2 ----- GF-GO6400SQ-N-A2
    Nvidia GF-GO6400 NPB ----- GF-GO6400 NPB
    Nvidia GF Go6800 B1 ----- GF Go6800 P-B1
    Nvidia GF Go6800 P-B1 ----- GF Go6800 P-B1
    Nvidia GF Go6800 U ----- GF Go6800 P-U1
    Nvidia GF Go6800 P-U1 ----- GF Go6800 P-U1
    Nvidia G84-303-A2 ----- G84-600-A2 -- G84-403-A2
    Nvidia G84-400-A2 ----- G84-600-A2 -- G84-403-A2
    Nvidia G84-403-A2 ----- G84-600-A2 -- G84-403-A2
    Nvidia G84-600-A2 ----- G84-600-A2
    Nvidia G84-625-A2 ----- G84-625-A2 -- G84-600-A2
    Nvidia G86-300-A2 ----- G86-731-A2 -- G86-730-A2
    Nvidia G86-302-A2 ----- G86-731-A2 -- G86-730-A2
    Nvidia G86-303-A2 ----- G86-731-A2 -- G86-730-A2
    Nvidia G86-602-A2 ----- G86-631-A2 -- G86-603-A2, G86-620-A2,G86-630-A2
    Nvidia G86-603-A2 ----- G86-631-A2 -- G86-630-A2
    Nvidia G86-620-A2 ----- G86-631-A2 -- G86-630-A2
    Nvidia G86-625-A2 ----- G86-635-A2 -- G86-630-A2
    Nvidia G86-630-A2 ----- G86-631-A2
    #68 bioshunger, Feb 8, 2017
  9. Tran Bao laptop
    Tran Bao laptop New Member
    ic 8A-1L thay thế đc con nào vậy add
  10. 01ifix
  11. ChetanSethi
    ChetanSethi Well-Known Member
    ati 216-0772034 equilant ????
  13. hoangkimsetup
    hoangkimsetup New Member
    A ThienBui giúp em tìm con ic tương đương với ic sạc BQ727 và IO NPCE885PAD0X với ạ,. Cảm ơn anh trước !
  14. vu hai duy
    vu hai duy Well-Known Member
    Fet tích hợp csd86350q5D mở nguồn CPU có xài chung được với con nào không ạ.
  15. Ptelemoveis
    Ptelemoveis Well-Known Member
    need bios acer nawf2 la-4853p rev 1.0 please
  16. DangNguyen
    DangNguyen New Member
    Xin cho tôi hỏi ic nguồn máy tính DM311A hỏng thay bằng IC gì các cậu nhỉ? Xin cám ơn tất cả.
  17. 01ifix
    NCP6132A = ?
  18. vu hai duy
    RT8239A=RT8239B=RT8239C Ngoài mấy con ad kể trên còn có con nào thay thế RT8239 được không ạ
  19. tankhanglaptop
    ite8987 thay đc bằng con j z ad
    chưa biết luôn :p
Similar Threads - Chipset Shared) equivalent Forum Date
Intel Core X-Series Processors (up to 18C/32T) and X299 Chipset Computer Hardware Repair May 30, 2017
Thảo luận Máy hàn chipset HT-R392 em mới mua như vầy có lõi không ạ Computer Hardware Repair Jun 13, 2016
BIOS PC ECS Chipset B85 BIOS/UEFI Nov 9, 2015
BIOS PC ECS Chipset H87 BIOS/UEFI Nov 9, 2015
BIOS PC ECS Chipset Z87 BIOS/UEFI Nov 9, 2015
