ASUS ROG GL502VS (7th Gen Intel Core)
Discussion in 'BIOS/UEFI' started by technical, May 21, 2017.
ASUS ROG GL502VS (7th Gen Intel Core) 5 5 2votes
5/5, 2 votes
    Intel® HM175 Express Chipset (7th #Kabylake)
    • Processor
      Intel® Core™ i7 7700HQ Processor,
      Intel® Core™ i5 7300HQ Processor,
    • Operating System
      Windows 10 Home
      Windows 10 Pro
    • Chipset
    • Memory
      2 x SO-DIMM socket for expansion, up to 32 GB SDRAM
    • Display
      15.6" (16:9) LED backlit FHD (1920x1080) 60Hz Anti-Glare Panel with 72% NTSC with 178˚ wide-viewing angle display
      with G-Sync
      15.6" (16:9) LED backlit FHD (1920x1080) 120Hz Anti-Glare Panel with 72% NTSC with 178˚ wide-viewing angle display
      with G-Sync
      15.6" (16:9) LED backlit UHD (3840x2160) 60Hz Anti-Glare Panel with 72% NTSC with 178˚ wide-viewing angle display
      with G-Sync
    • Graphic
      NVIDIA GeForce GTX 1070 , with 8GB VRAM
    • Storage
      Hard Drives:
      1TB 5400RPM SATA HDD
      1TB 7200RPM SATA HDD
      2TB 5400RPM SATA HDD
      Solid State Drives:
      128GB/256GB/512GB SATA3 SSD
      Solid State Drives:
      128GB/256GB/512GB PCIE Gen3X4 SSD
    • Keyboard
      Illuminated Chiclet Keyboard
    • Card Reader
      Multi-format card reader (SDHC/SDXC/MMC)
    • WebCam
      HD Web Camera
    • Networking
      Wi-Fi
      Integrated 802.11b/g/n
      Integrated 802.11 AC
      Bluetooth
      Built-in Bluetooth V4.0
    • Interface
      1 x Microphone-in/Headphone-out jack
      1 x Type A USB3.0 (USB3.1 GEN1)
      3 x Type A USB3.0 (USB3.1 GEN1)
      1 x RJ45 LAN Jack for LAN insert
      1 x HDMI
      1 x mini Display Port
      1X AC adapter plug
    • Audio
      Support Windows 10 Cortana with Voice
      ASUS SonicMaster Technology
    • Battery
      4 Cells 62 Whrs Battery
    • Power Adapter
      Plug Type :ø5.5 (mm)
      Output :
      19.5 V DC, 9.23 A, 230 W
      Input :
    • Dimensions
      Tablet:
      390 x 266 x 30.1 mm (WxDxH)
    • Weight
      Tablet:
      2.3 kg with Battery
    • Security
      Kensington lock
      BIOS Booting User Password Protection
    • Certificates
      UL, TUV, CE Marking Compliance, FCC Compliance, BSMI, Australia C-TICK / NZ A-Tick Compliance, CCC, GOST-R, CB, Energy star, WEEE, RoHS
    • Manufacturer Warranty
      1-year limited International hardware warranty. *different by country
    • VR
      VR Ready
    • Gaming Series
      GL Series
    #1 technical, May 21, 2017
    Similar Threads - ASUS GL502VS (7th Forum Date
    ASUS GL502VSK BIOS/UEFI Dec 5, 2018
    Asus ROG GL502VS BIOS/UEFI Sep 3, 2016
  3. williamwps
    williamwps New Member
    I need this bios gl502vs
    send old bios error I build...
  5. Ebarduil
    Ebarduil Well-Known Member
    Hi, i need bios Asus GL502vy
  7. 18ifix
    18ifix Moderator
    i have g502vs i7 th
  8. Nasir Mahmood
    Nasir Mahmood Well-Known Member
    hi sir plz fix this bios no display i am sure this bios pro
    GL502VSK.308.bin
  10. Reballing Catania
    Reballing Catania New Member
    I my friedn i have problem with bios GL502vs rev2.1 i7-7700 - 2 slot ram ddr4 - GTX1070 please help attach dump (problem break during update)
  12. Reballing Catania
    same problem, but i have another winbond 25x80e possible these damege code?
    can skip 1MB
  14. Reballing Catania
    provided result Programming bios i send above, Understand or not ?
  16. Reballing Catania
    thienBui with your bios same problem, caps lock and power key on but no video and no spin fan.
    could the problem be on the other eprom 25q80e since it stopped during the update?
    send file 1MB i check, i not see you send above ?
  18. Reballing Catania
    ok read 25q80e
  19. Reballing Catania
  20. Reballing Catania
    the customer turned off during the update. with the bios try it remains the same no fans no video only caps lock access and power led
