HP ZBook 17 G2 LA-B391P BIOS
Discussion in 'BIOS/UEFI' started by technical, May 14, 2017.
HP ZBook 17 G2 LA-B391P BIOS 5 5 1votes
    Not need CLear and not unlock, here is problem DMI, bios you send above how ?
    You need to understand this before asking.
  2. remont_volodja
    remont_volodja New Member
    I understand this. Yes i need clear the DMI information from this bios.
    all i provided above how? Please try and take photo error i need see...
  4. remont_volodja
    This is modified Bios that you sent me with "Clear" ME Region
    no, i need see error where boot, i no need see error where fix tool.
    Because some tool machines do not support.
    Programming bios send above you see error what?
  6. remont_volodja
    This is a error where boot after programming your bios
  8. remont_volodja
    Yes, I Programming this Bios, and the same error
  9. remont_volodja
    Hello.
    Can somebody help me fix this problem? PLEASE!
    Same error Please check hardware, all bios can not same error and i can not help more....
  11. remont_volodja
    What do you mean by "Please check hardware"?
    I still consider that the problem is in Bios. And intend to figure out where exactly is the problem. Can you send me 100% working bios dumps EC + MAIN for platform: HP ZBook 17 G2 LA-B391P
    And later i'l report where was the problem.
    all bios above 100% backup laptop work.
  13. remont_volodja
    i searched all your forum for bios EC and MAIN dumps for
    HP ZBook 17 G2 LA-B391P except those dumps that I sent to you and you modofied and sent back. So I think that you didn't test that bios you've "modofied" and you can't garantee it's 100% working. But you still screem that bios is working, though it is not true and you've never tested it. I tested every single bios you "modofied" and still MPM is locked.
    I suspect you need to find out more about the BIOS, It's not as simple as you think.
  15. 03ifix
    Try this and reply.And old original bios problem what?
    You need know old BIOS can not error HPH, I sure here is one bios other not is old.
  17. 03ifix
    Sorry my question is remont_volodja.
  18. remont_volodja
    imranromi said: Try this and reply.
    your bios is working. everything works. but my problem remains * machine is not in committed state *
  19. 03ifix
  20. laptoptpt
    laptoptpt Well-Known Member
    ad cho xin con 25Q16 với
Similar Threads - ZBook B391P BIOS Forum Date
HP-Compaq Zbook 17 g3 BIOS/UEFI Aug 6, 2019
EZBOOK I7 H84 MB VER C BIOS/UEFI May 7, 2019
HEEELP SOME RESISTANCE REMOVED HP ZBook Studio G3 LA-C401P Computer Hardware Repair Apr 1, 2019
HP-Compaq HP ZBook Studio G3 Mobile Workstation LA-C401P APW5U Rev:1A BIOS/UEFI Mar 29, 2019
HP-Compaq Pls Help Me To Remove Password in HP ZBook 17 LA-9371P REV 1.0 BIOS/UEFI Mar 1, 2019
