ACER VN7-791G-73TH BIOS HELP (860m)
Discussion in 'Computer Hardware Repair' started by Jose_Angel_Galvez_Saez, Jun 27, 2018.
  1. Jose_Angel_Galvez_Saez
    Jose_Angel_Galvez_Saez New Member
    No boot, fan spins, keyboard lighting on, probably bios corruption, reprogammed chip with bios dump from https://vinafix.com/threads/acer-aspire-vn7-791-791g-14203-2.14775/ post #6
    now pc seems to boot normally, normal fan sequence but no image on screen.
    I want to check if the bios I reprogrammed is the one I was supposed to use.
    Attached original bios. Thanks!
    Similar Threads - ACER 791G 73TH Forum Date
    Acer-Gateway Acer Aspire VN7-791/791G 14203-2 Schematics May 1, 2015
    Acer A315-22-49ZE Bordviwe Schematics Jun 15, 2021
    Schematics PC Acer 5742g la-6582p R 1.0 Schematics Schematics Jul 1, 2020
    BIOS you send error what?
  4. Jose_Angel_Galvez_Saez
    Bios I send is original backup after laptop no boot, both fan spins at start, then only small fan accelerate every 2-3 seconds forever, my prediction is bios corruption.
    No errors in bios?
    So what does our BIOS provide above?
  6. Jose_Angel_Galvez_Saez
    normal boot, nothing strange with fans, but no image on screen.
    your bios should work normally?
    check hardeare.
  8. Jose_Angel_Galvez_Saez
    Thankyou, wanted to discard bios as the problem.
