AOC B101AW01(V2)
Discussion in 'ELECTRONIC DEVICE' started by technical, Dec 10, 2014.
    B101AW01(V2)
    1. Handling Precautions
    1) Since front polarizer is easily damaged, pay attention not to scratch it.
    2) Be sure to turn off power supply when inserting or disconnecting from input connector.
    3) Wipe off water drop immediately. Long contact with water may cause discoloration or
    spots.
    4) When the panel surface is soiled, wipe it with absorbent cotton or other soft cloth.
    5) Since the panel is made of glass, it may break or crack if dropped or bumped on hard
    surface.
    6) Since CMOS LSI is used in this module, take care of static electricity and insure
    human earth when handling.
    7) Do not open nor modify the Module Assembly.
    8) Do not press the reflector sheet at the back of the module to any directions.
    9) At the insertion or removal of the Signal Interface Connector, be sure not to rotate nor
    tilt the Interface Connector of the TFT Module.
    10) After installation of the TFT Module into an enclosure (Notebook PC Bezel, for
    example), do not twist nor bend the TFT Module even momentary. At designing the
    enclosure, it should be taken into consideration that no bending/twisting forces are
    applied to the TFT Module from outside. Otherwise the TFT Module may be
    damaged.
