BIOS PC B150M-D D3
    B150M-D D3
    BIOS B150M-D-D3-ASUS-0209 16MB
    Great-value micro-ATX B150 with 5X Protection II for dependable stability, LED-illuminated audio shielding and flexible DDR3/DDR3L compatibility
    • 5X Protection II – Advanced hardware safeguards for all-round protection
    • DDR3/DDR3L memory compatibility
    • Epic gaming audio with LED-illuminated shielding
    • Media-acclaimed UEFI BIOS with EZ Flash 3
    • CPU
      Intel® Socket 1151 for 6th Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
      Supports Intel® 14 nm CPU
      * The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
      * Refer to www.asus.com for CPU support list
    • Chipset
      Intel® B150
    • Memory
      2 x DIMM, Max. 32GB, DDR3 1866(O.C.)/1600/1333 MHz Non-ECC, Un-buffered Memory *
      Dual Channel Memory Architecture
      Supports Intel® Extreme Memory Profile (XMP)
      * Hyper DIMM support is subject to the physical characteristics of individual CPUs.
      * Refer to www.asus.com for the Memory QVL (Qualified Vendors Lists).
    • Graphic
      Integrated Graphics Processor- Intel® HD Graphics support
      Multi-VGA output support : DVI-D/RGB ports
      - Supports DVI-D with max. resolution 1920 x 1200 @ 60 Hz
      - Supports RGB with max. resolution 1920 x 1200 @ 60 Hz
      Maximum shared memory of 1024 MB
      Supports Intel® InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
    • Expansion Slots
      1 x PCIe 3.0/2.0 x16 (x16 mode, gray)
      2 x PCIe 3.0/2.0 x1
      1 x PCI
    • Storage
      Intel® B150 chipset :
      6 x SATA 6Gb/s port(s), gray
    • LAN
      Realtek® RTL8111H, 1 x Gigabit LAN Controller(s)
      ASUS LAN Guard
    • Audio
      Realtek® ALC887 8-Channel High Definition Audio CODEC *1
      - Supports : Jack-detection, Front Panel Jack-retasking
      Audio Feature :
      - LED-illuminated design - Brighten up your build with the gorgeous illuminated audio trace path.
      - Audio Shielding: Ensures precision analog/digital separation and greatly reduced multi-lateral interference
      - Dedicated audio PCB layers: Separate layers for left and right channels to guard the quality of the sensitive audio signals
      - Premium Japanese-made audio capacitors: Provide warm, natural and immersive sound with exceptional clarity and fidelity
    • USB Ports
      6 x USB 2.0/1.1 port(s) (2 at back panel, black, Type-A, 4 at mid-board)
      6 x USB 3.0/2.0 port(s) (4 at back panel, blue, Type-A, 2 at mid-board)
    • Special Features
      ASUS 5X Protection II :
      - ASUS LANGuard - 2.5X higher surge tolerance
      - ASUS Overvoltage Protection - World-class circuit-protecting power design
      - ASUS DIGI+ VRM - 6 Phase digital power design
      - ASUS DRAM Overcurrent Protection - Prevents damage from short circuits
      - ASUS Stainless-Steel Back I/O - 3X corrosion-resistance for greater durability
      ASUS EPU :
      - EPU
      ASUS Exclusive Features :
      - GPU Boost *3
      - AI Suite 3
      - Ai Charger
      - Anti-Surge
      - USB 3.0 Boost
      - Disk Unlocker
      - Mobo Connect
      - PC Cleaner
      ASUS Quiet Thermal Solution :
      - Stylish Fanless Design Heat-sink solution
      - ASUS Fan Xpert
      ASUS EZ DIY :
      - ASUS CrashFree BIOS 3
      - ASUS EZ Flash 3
      - ASUS UEFI BIOS EZ Mode
      - Push Notice
      ASUS Q-Design :
      - ASUS Q-Slot
      - ASUS Q-DIMM
      Media Streamer
    • Operating System Support
      Windows® 10 , 64bit
      Windows® 8.1 , 64bit
      Windows® 7 , 32bit/64bit *2
    • Back I/O Ports
      1 x PS/2 keyboard/mouse combo port(s)
      1 x DVI-D
      1 x D-Sub
      1 x LAN (RJ45) port(s)
      4 x USB 3.0 (blue) Type-A
      2 x USB 2.0
      1 x Parallel port(s)
      3 x Audio jack(s)
    • Internal I/O Ports
      1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin)
      2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
      1 x COM port(s) connector(s)
      6 x SATA 6Gb/s connector(s)
      1 x CPU Fan connector(s) (1 x 4 -pin)
      1 x Chassis Fan connector(s) (1 x 4 -pin)
      1 x S/PDIF out header(s)
      1 x 4-pin ATX 12V Power connector(s)
      1 x Front panel audio connector(s) (AAFP)
      1 x System panel(s)
      1 x Clear CMOS jumper(s)
    • Accessories
      User's manual
      I/O Shield
      2 x SATA 6Gb/s cable(s)
      1 x Supporting DVD
    • BIOS
      128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0, ACPI 5.0, Multi-language BIOS, ASUS EZ Flash 3, CrashFree BIOS 3, F6 Qfan Control, F3 My Favorites, Quick Note, Last Modified log, F12 PrintScreen, and ASUS DRAM SPD (Serial Presence Detect) memory information
    • Manageability
      WfM 2.0, DMI 3.0, WOL by PME, PXE
    • Support Disc
      Drivers
      ASUS Utilities
      EZ Update
      Anti-virus software (OEM version)
    • Form Factor
      mATX Form Factor
      9.6 inch x 7.2 inch ( 24.4 cm x 18.3 cm )
    • Note
      *1: Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
      *2: Please refer to ASUS website and download “Windows® 7 installation guide” and “ASUS EZ installer” to install Windows® 7.
      *3: The funcation supported varies by processor
    #1 technical, Sep 16, 2015
    Similar Threads - B150M Forum Date
    Schematics PC GA-B150M-D3H DDR3 Schematics Aug 16, 2019
    Schematics PC GA-B150M-EVO Schematics Aug 16, 2019
    BIOS PC CF-G10-MX V20 B150M-K BIOS/UEFI Jul 2, 2019
    Schematics PC ASUS B150M-ET M2 Schematics Jul 1, 2019
    BIOS PC GA-B150M-DS3H BIOS/UEFI Jun 21, 2019
