Full System Precision CCFL Driver MP1015
Discussion in 'Computer Hardware Repair' started by 16ifix, Apr 14, 2015.
    General Description
    The MP1015 is a Power IC that offers a true complete solution for driving a Cold Cathode
    Fluorescent Lamps (CCFL). This Power IC converts unregulated DC voltage to a nearly pure
    sine wave required to ignite and operate the CCFL. Based on proprietary power topology and control
    techniques (patented), it greatly increases the power conversion efficiency. The MP1015 can be
    used with analog or burst mode dimming without any additional external components. The MP1015
    offers four distinct performance advantages:
    1. More light for less power
    2. Smallest board implementation possible
    3. Low EMI emission
    4. Low cost off the shelf components
    Features
    - Built-in Burst Mode Oscillator and Modulator
    - Built-in Analog and Burst Mode Dimming
    - Built-in Current and Voltage Feedback Control
    - Built-in Open/Short Lamp Protection
    - Built-in Dual Mode Fault Timer
    - Built-in Soft-on/Soft-off Burst Mode
    - Automatic Recovery from ESD Event
    - Wide Range 6 to 22V Battery Voltage with Regulated Lamp Current
    - Startup at all voltages and temp without additional components
    - Integrated 0.10Ω Power Switches
    - Output Short Circuit Protected
    - No High Voltage Ballast Capacitor
    - Evaluation Board Available
    MP1015.
    Brightness Control
    The MP1015 can operate in three modes: Analog Mode, Burst Mode with a DC input, or Burst Mode
    with an external PWM. The three modes are dependent on the pin connections as per Table 1.
    Choosing the required burst repetition frequency can be achieved by an RC combination, as defined
    in component selection. The MP1015 has a soft on and soft off feature to reduce noise, when using
    burst mode dimming.
    Synchronous Buck Controller ADP3212 NCP3218
    #1 16ifix, Apr 14, 2015
    Similar Threads - Full System Precision Forum Date
    HP Probook 470 G3 -"Your system is not fully configured - contact your hp customer support" Computer Hardware Repair Jun 30, 2018
    MTK CPU, PMIC, RF transceiver device full specification Tablet | Smartphone Mar 31, 2019
    TV LG 42LA6130 FULL HD LED TV ELECTRONIC DEVICE Feb 21, 2019
    TV LG 42LV3500 1920 x 1080 FULL HD LED TV ELECTRONIC DEVICE Feb 21, 2019
    TV VU 24E6545 24 inch LED Full HD ELECTRONIC DEVICE Jan 26, 2019
  3. 16ifix
    MP1015EM
