BIOS PC H170M-PLUS
BIOS PC H170M-PLUS 5 5 1votes
    H170M-PLUS BIOS
    H170M-PLUS-ASUS-0406
    Full-featured micro-ATX H170 with 5X Protection II for dependable stability, DDR4 support, and reversible USB Type-C connectivity
    • 5X Protection II – Advanced hardware safeguards for all-round protection
    • Lightning-fast M.2 with PCIe® 3.0 x4 interface
    • USB Type-C for convenient connectivity
    • Epic gaming audio with noise-isolation design
    • Media-acclaimed UEFI BIOS with EZ Flash 3
    • Fan Xpert 2+ advanced fan controls for ultimate cooling and silent performance
    • CPU
      Intel® Socket 1151 for 6th Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
      Supports Intel® 14 nm CPU
      * The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
    • Chipset
      Intel® H170
    • Memory
      4 x DIMM, Max. 64GB, DDR4 2133 MHz Non-ECC, Un-buffered Memory *
      Dual Channel Memory Architecture
      Supports Intel® Extreme Memory Profile (XMP)
      * Hyper DIMM support is subject to the physical characteristics of individual CPUs.
      * The maximum memory frequency supported varies by processor.
      * Due to Intel® chipset limitation, DDR4 2133 MHz and higher memory modules on XMP mode will run at the maximum transfer rate of DDR4 2133 Mhz.
    • Graphic
      Integrated Graphics Processor- Intel® HD Graphics support
      Multi-VGA output support : HDMI/DVI/DVI-D/RGB ports
      - Supports HDMI with max. resolution 4096 x 2160 @ 24 Hz / 2560 x 1600 @ 60 Hz
      - Supports DVI-D with max. resolution 1920 x 1200 @ 60 Hz
      - Supports RGB with max. resolution 1920 x 1200 @ 60 Hz
      Maximum shared memory of 1024 MB
      Supports Intel® InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
      Supports up to 3 displays simultaneously
    • Multi-GPU Support
      Supports AMD Quad-GPU CrossFireX™ Technology
    • Expansion Slots
      1 x PCIe 3.0/2.0 x16 (x16 mode, gray)
      1 x PCIe 3.0/2.0 x16 (max at x4 mode)
      2 x PCIe 3.0/2.0 x1
    • Storage
      Intel® H170 chipset :
      1 x M.2 Socket 3, , with M key, type 2242/2260/2280 storage devices support (both SATA & PCIE mode)
      1 x SATA Express port, gray, Compatible with 2 x SATA 6.0 Gb/s ports
      6 x SATA 6Gb/s port(s), gray
      Support Raid 0, 1, 5, 10
      Supports Intel® Smart Response Technology*1
    • LAN
      Intel® I219V, 1 x Gigabit LAN Controller(s)
      Intel® LAN- Dual interconnect between the Integrated LAN controller and Physical Layer (PHY)
    • Audio
      Realtek® ALC887 8-Channel High Definition Audio CODEC *2
      - Supports : Jack-detection, Front Panel Jack-retasking
      Audio Feature :
      - Audio Shielding: Ensures precision analog/digital separation and greatly reduced multi-lateral interference
      - Dedicated audio PCB layers: Separate layers for left and right channels to guard the quality of the sensitive audio signals
      - Premium Japanese-made audio capacitors: Provide warm, natural and immersive sound with exceptional clarity and fidelity
    • USB Ports
      6 x USB 2.0/1.1 port(s) (2 at back panel, black, Type-A, 4 at mid-board)
      6 x USB 3.0/2.0 port(s) (2 at back panel, blue, Type-A, 4 at mid-board)
      1 x USB 5Gb/s port(s) port(s) (1 at back panel, black, Type-C, Reversible, Support 3A power output)
    • Special Features
      ASUS 5X Protection II :
      - ASUS LANGuard - 2.5X higher surge tolerance
      - ASUS Overvoltage Protection - World-class circuit-protecting power design
      - ASUS DIGI+ VRM - 7 Phase digital power design
      - ASUS DRAM Overcurrent Protection - Prevents damage from short circuits
      - ASUS Stainless-Steel Back I/O - 3X corrosion-resistance for greater durability
      ASUS EPU :
      - EPU
      ASUS Exclusive Features :
      - GPU Boost *3
      - AI Suite 3
      - Ai Charger
      - M.2 & SATA Express
      - Anti-Surge
      - ESD Guards
      - USB 3.0 Boost
      - Disk Unlocker
      - Mobo Connect
      - PC Cleaner
      ASUS Quiet Thermal Solution :
      - Stylish Fanless Design Heat-sink solution & MOS Heatsink
      - ASUS Fan Xpert 2+
      ASUS EZ DIY :
      - ASUS CrashFree BIOS 3
      - ASUS EZ Flash 3
      - ASUS UEFI BIOS EZ Mode
      - Push Notice
      ASUS Q-Design :
      - ASUS Q-Slot
      - ASUS Q-DIMM
      Media Streamer
    • Operating System Support
      Windows® 10 , 64bit
      Windows® 8.1 , 64bit
      Windows® 7 , 32bit/64bit *4
    • Back I/O Ports
      1 x PS/2 keyboard (purple)
      1 x PS/2 mouse (green)
      1 x DVI-D
      1 x D-Sub
      1 x HDMI
      1 x LAN (RJ45) port(s)
      1 x USB 5Gb/s port(s) Type-C ( support 3A power output )
      2 x USB 3.0 (blue) Type-A
      2 x USB 2.0
      3 x Audio jack(s)
    • Internal I/O Ports
      2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s) (19-pin)
      2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
      1 x SATA Express connector: gray, Compatible with 2 x SATA 6.0 Gb/s ports
      1 x M.2 Socket 3
      1 x TPM header
      1 x LPT header
      1 x COM port(s) connector(s)
      6 x SATA 6Gb/s connector(s)
      1 x CPU Fan connector(s) (1 x 4 -pin)
      2 x Chassis Fan connector(s) (2 x 4 -pin)
      1 x S/PDIF out header(s)
      1 x 8-pin ATX 12V Power connector(s)
      1 x Front panel audio connector(s) (AAFP)
      1 x System panel(s)
      1 x Clear CMOS jumper(s)
    • Accessories
      User's manual
      I/O Shield
      2 x SATA 6Gb/s cable(s)
      1 x M.2 Screw Package
      1 x Supporting DVD
    • BIOS
      128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0, ACPI 5.0, Multi-language BIOS, ASUS EZ Flash 3, CrashFree BIOS 3, F11 EZ Tuning Wizard, F6 Qfan Control, F3 My Favorites, Quick Note, Last Modified log, F12 PrintScreen, and ASUS DRAM SPD (Serial Presence Detect) memory information
    • Manageability
      WfM 2.0, DMI 3.0, WOL by PME, PXE
    • Support Disc
      Drivers
      ASUS Utilities
      EZ Update
      Anti-virus software (OEM version)
    • Form Factor
      mATX Form Factor
      9.6 inch x 8.95 inch ( 24.4 cm x 22.7 cm )
    • Note
      *1: These functions will work depending on the CPU installed.
      *2: Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
      *3: The function supported varies by processor
      *4: Please refer to ASUS website and download “Windows® 7 installation guide” and “ASUS EZ installer” to install Windows® 7.
    #1 technical, Sep 16, 2015
    Similar Threads - H170M PLUS Forum Date
    Schematics PC GA-H170M-D3HP Schematics Mar 21, 2018
    Schematics PC GA-H170M-DS3H Schematics Mar 16, 2018
    Schematics PC GA-H170M-HD3 DDR3-1.0 BV Schematics Mar 16, 2018
    Schematics PC ASROCK H170M PRO4 R1.02 (70-MXGZL0-A11).fz Schematics Feb 25, 2018
    Schematics PC ASROCK H170M PRO4S R1.02 (70-MXGZW0-A01).fz Schematics Feb 25, 2018
    Asus H170M-PLUS RG
