HP-Compaq hp 840 g2 MPM is not unlocked
Discussion in 'BIOS/UEFI' started by jasko_jacker_1, Dec 11, 2016.
HP-Compaq hp 840 g2 MPM is not unlocked 5 5 2votes
5/5, 2 votes
  1. jasko_jacker_1
    jasko_jacker_1 New Member
    Hi,
    The owner has changed the bios chip and maybe even me chips.
    After I reprogrammed the bios and not the me chip, the notebook starts but
    in order to remove this message "machine is not in committed state" I try first the boot from uefi file method (brand11, etc) , after, i try hp dmi tool, both with no luck.
    After I have tryed on windows wndmifit but appear this message:
    "MPM is not unlocked.....please escalate with UUID to get SMC blob to unlock MPM"
    I have read to modify the FSMC.bin file to SMC.bin file and change the file lockmpm.txt but the MPM is still locked.
    My UUID is not FFFFFFFFFFFFFFF
    I have reprogrammed the bios with different files but MPM is still locked.
    There is a solution from this issue ?
    Similar Threads - unlocked Forum Date
    BIOS PC Inspiron 537s Unlocked BIOS ( G41T-DM ) AHCI BIOS/UEFI Jun 29, 2021
    HP-Compaq HELP ME unlocked MPM HP 1040 G3 BIOS/UEFI Aug 6, 2018
  4. jasko_jacker_1
  6. jasko_jacker_1
    Finally I solve only the machine is not in committed state issue,
    Remain to solve how change the UUID on ec to all FF if you want to change serial and other info. Maybe it's possible with hex editor but at the owner not interst the change.
    thanks for help
  7. andrew_77
    andrew_77 New Member
    Please tell me how to fix the "machine is not in committed state" issue? You wrote that you did....
    I would also like to know how to unlock MPM counter.
    Not always flash programmer gives the effects of what I am looking for.
    thank you in advance
    • Angry Angry x 1
  9. jawaljawad37
    jawaljawad37 Well-Known Member
    hi i have this problem how you solve it thinks
    View link above.
  11. jawaljawad37
    yes i have test this procedur not work win i want unlock mpm i have errue in smc faileur in brand 14 i have errur cant not comit
  12. jawaljawad37
    problem is fix okk
    me region clean and bios region clean
