Hp cpqtag chỉnh sửa Model, SKU, Serial, Sysbrdct
Discussion in 'Computer Hardware Repair' started by technical, Jan 22, 2014.
Hp cpqtag chỉnh sửa Model, SKU, Serial, Sysbrdct 5 5 1votes
    cpqtag write model "EliteBook 8560W"
    product number:cpqtag write SKU "XXXX"
    serial number:cpqtag write serial "XXXX"
    system board CT:cpqtag write sysbrdct "XXX"
    Usage: CPQTAG.EXE [CMD] [TYPE] {string}
    CMD = READ/WRITE/CHECK/MODIFY/GENERATE (REQUIRED)
    TYPE = SERIAL/ASSET/MODEL/ID/SKU/MBSN/TPM/SLP/FASTLOOK/DIGIPANELSUPPORT (REQUIRED)
    VPRO/WWAN/DEFAULTS/FLASHID/OWNER/CONFIGID/OSTYPE/
    ATP/ME/COMPUTRACE/FNKEYSWITCH/PRODLINE/SYSBRDCT
    string = Data to write (optional for READ command)
    CPQTAG read serial
    CPQTAG write model M700
    CPQTAG modify asset 6622HVS3P025
    CPQTAG read TPM
    CPQTAG write TPM [ON,OFF]
    CPQTAG read SLP
    CPQTAG write SLP [ON,OFF]
    CPQTAG read VPRO [VPRO_STATE,DESCRIPTOR_STATE,MGMT_ENGINE_STATE,OVERRIDE_STATE]
    CPQTAG write VPRO [ON,OFF,LOCK,RESET]
    CPQTAG write ME [ON,OFF]
    CPQTAG write ME [LOCK | UNCOMMIT]
    CPQTAG read ME [STATUS]
    CPQTAG reboot [VPRO | ME]
    CPQTAG read WWAN
    CPQTAG write WWAN [ANTENNA] [NOANTENNA]
    CPQTAG write WWAN [GPS] [NOGPS]
    CPQTAG write WWAN [OP0,OP1,...OP7]
    CPQTAG write WWAN CLEAR
    CPQTAG write DEFAULTS
    CPQTAG read FLASHID (TT 1.0 systems only)
    CPQTAG write OWNER Hewlett-Pacakard Company
    CPQTAG write RESETKEYS ON
    CPQTAG write configid
    CPQTAG write PTDEFAULTS
    CPQTAG write MPM (Manufacturing Program Mode, formerly - FACTORYMODE
    CPQTAG read BraidWood
    CPQTAG write BraidWood [Default, Erase, Destroy, Create]
    CPQTAG write OsType
    CPQTAG write WWANWMI
    CPQTAG write VT
    CPQTAG write SOFTSTYLUS [SUPPORTED, NOTSUPPORTED]
    CPQTAG write ATP OFF
    CPQTAG read ATP
    CPQTAG write COMPUTRACE [ENABLE | DISABLE] (Write once/locked)
    CPQTAG write RESETWSD
    CPQTAG read FASTLOOK
    CPQTAG write FASTLOOK [ON,OFF]
    CPQTAG read DIGIPANELSUPPORT
    CPQTAG write DIGIPANELSUPPORT [ON,OFF]
    CPQTAG write FNKEYSWITCH [ENABLE | DISABLE]
    CPQTAG write ESTAR [ON,OFF]
    CPQTAG read OOCLVDS
    CPQTAG write OOCLVDS [DEFALUTTABLE|NULL|panel.txt]
    CPQTAG read | write PRODLINE
    CPQTAG read | write SYSBRDCT
    CPQTAG read | write FCM (FactoryControlMode) [0 - 7]
    You must reboot the system with 'CPQTAG reboot VPRO'
    after locking VPro configuration with one of:
    'CPQTAG write VPRO [ON,OFF,LOCK,RESET]
    Similar Threads - cpqtag chỉnh sửa Forum Date
    Tin tức Samsung chính thức giới thiệu Galaxy Tab E iOS - iPhone,iPad,iPod Aug 13, 2015
    Tool chỉnh sửa MAC và reset mật khẩu Computer Hardware Repair Aug 2, 2015
    Tin tức Windows RT chính thức bị khai tử iOS - iPhone,iPad,iPod Feb 4, 2015
    Thủ thuật 5 Bí quyết kỹ thuật căn chỉnh Amply Karaoke hay tuyệt vời Windows PC Nov 11, 2014
    Tin tức iPad Air 2 mỏng nhất thế giới chính thức trình làng iOS - iPhone,iPad,iPod Oct 17, 2014
