KID R600 REWORK STATION User Manual
Discussion in 'Computer Hardware Repair' started by technical, Nov 26, 2014.
KID R600 REWORK STATION User Manual 5 5 1votes
    KID R600.
    I. Installation and Operating Precautions
    To ensure safety and prevent possible damage to the rework station, it is required to install
    the rework station at a location complying with the following conditions.
    ◆ Away from inflammables.
    ◆ Free from splashing of water or other liquids.
    ◆ Free from the direct airflow impact from air conditioner, heater or ventilator.
    ◆ With good ventilation, dry location, free from excessive dust.
    ◆ Free from vibration or shock, at a stable and flat location.
    Power Supply
    Power and voltage should meet the following requirements:
    ◆ Use the power supply with little voltage fluctuation
    Voltage fluctuation: AC220V±10%。
    Frequency fluctuation: 50/60Hz±0. 3%
    Space Requirements
    To facilitate operation, component replacement and maintenance for the rework station,
    it is required to reserve >300mm space at the back of the rework station.
    Similar Threads - R600 REWORK STATION Forum Date
    TV Panasonic TX-32ASR600, TX-32ASR605 service manual ELECTRONIC DEVICE Jul 22, 2019
    Toshiba Portege R600 (PPR65U) BIOS BIOS/UEFI Jun 7, 2017
    MSI VR600 - MS-1613 BIOS/UEFI Jul 20, 2015
    MSI MSI FR600 MS-16G11 BIOS/UEFI Jul 3, 2015
    LY-ACHI-IR6000 Manual Computer Hardware Repair Nov 26, 2014
  3. Roman66
    Roman66 New Member
    Hello. Tell me, please, could you send me the exact settings for Bga Rework Station W-KIDI KID R600. The machine is, the guide and the drive is lost. If possible, please send, settings. Thank you in advance. I will be very grateful for the help.Please help solve the problem of professional settings.I can not accurately configure KID R600..KID R600 not properly remove the chip and not properly put in place
  4. Roman66
    Roman66 New Member
  5. Roman66
    Roman66 New Member
  6. Roman66
    Roman66 New Member
    SV560A BGA Rework Station the same parameters.I need to configure temprature
  7. Erhan$
    Erhan$ New Member
  8. Roman66
    Roman66 New Member
    my friend, you once helped me find. I really ask you, help me find a file for usb flesh so that I can restore to the factory settingswe are both specialists, do a good deed to the Supreme. I will be very grateful to you my friendHelp me find a file to reset to factory settings. I beg you very much
