Hello mate.. i have a motherboard with rather weird condition. The motherboard is HP Irvine GL6E, LGA 775/Socket T, Intel (MCP73S01) Motherboard. Single chipset nvdia for lga775. If i turn to power switch or short with metal from the ps-on front panel, the fan just twitch.. Seems mosfet shorted.. So, i check with multimeter all the mosfet, including vrm, memory section, etc. But every mosfet that i checked seems normal... With confuse, i try to jumper green-black cable through the 24 pin socket in motherboard. The motherboard now turn-on, and the funny thing is, it's now beep. A single beep that sign the system is ready.. So i connect it to the monitor and it has display. Trying to install windows, everything is running. But, if pull out the jumper, the motherboard shutdown. And if i try to turn on through front panel, fan just twitch again.. So, what's is the problem, and where i have to start to check..? Thanks a lot.
