Schematics PC MS-91A3
Discussion in 'Schematics' started by technical, Nov 5, 2014.
    Main Server MS-91A3
    MSI Global MS-91A3(BTO)
    comp19_18.
    CPU
    • Supports Intel® Xeon (Nehalem-EP) x 1~2 processors up to 130W in Socket LGA1366
    QPI (up to 6.4GT/s)
    • Northbridge: Intel® Tylersburg-36D
    • Southbridge: Intel® ICH10R
    12 x DDR3 1066/1333 Support both RDIMM & UDIMM (3 Channel) slots
    • Maximum Up to 96GB Registered DIMM or 48GB Unbuffered DIMM ECC
    • 1 PCI-Express(x16) slot
    • 3 PCI-Express(x8) slot
    • 1 PCI 32bit/33MHz/5V slot
    • 1 FDD connector
    • 1 SATAII connector for Optical Drive
    • 4 SATAII connectors
    - 1 PS/2 mouse port
    - 1 PS/2 keyboard port
    - 1 serial port
    - 4 USB 2.0 ports
    - 1 RJ-45 Gigabit LAN ports
    - 1 IEEE1394
    - 1 NMI button
    - 1Stacked Line-in, Line-out and Mic-in ports ( 2.1 Channel Audio)
    - 1 USB 2.0 connector
    - 1 serial port connector
    - 1 USB2.0 + IEEE1394 connector
    - 1 audio connector
    • 10/100/1000 Base-T x1 [ICH10R + Boazman(82567)]
    • 2 IEEE 1394 ports by TI TSB43AB22A-G4
    • Transfer rate is up to 400Mbps
    Extended ATX
    #1 technical, Nov 5, 2014
