Main Server MS-91A4 THIDWICK IU POWEREDGE R610 * Dell PowerEdge R610 Server * 1 x Intel® Xeon Quad Core E5640 2.66Ghz 12MB L3 5.86GT/s Turbo, HT (Support Intel® Xeon® 5500 and 5600 Sequence - 8 Processor Cores) * 2 x 2GB Dual Rank ECC RDIMMs 1333Mhz memory (Up to 192GB) * 1 x 500GB Hot-Plug SATA 3Gbps 7200rpm 2.5" (Max 6HDDs) * Power supply 502Watts Non-Redundant Processors Intel® Xeon® processor 5500 and 5600 series Six-Core Intel® Xeon® Quad-Core Intel® Xeon® Chipset IntelTM 5520 (Tylersberg) Memory Up to 192GB3 (12 DIMM slots/6 per-processor): 1GB/2GB/4GB/8GB/16GB DDR3 800MHz, 1066MHz or 1333MHz Embedded Hypervisor (Optional) Citrix® XenServer® Microsoft® Windows Server® 2008, with Hyper-VTM VMware® ESXiv 3.5 Operating Systems Microsoft® Windows® Small Business Server 2008 Microsoft® Windows® Essential Business Server 2008 Microsoft Windows® Server 2008 SP2, x86/x64 (x64 includes Hyper-VTM ) Microsoft Windows® Server 2008 R2, x64 (includes Hyper-VTM v2)Microsoft® Windows® HPC Server 2008 Novell® SUSE® Linux Enterprise Server Red Hat® Enterprise Linux Sun® SolarisTM Storage SAS, Near-line SAS, SSD and SATA: PERC H200 (6Gb/s) PERC H700 (6Gb/s) with 512MB Non-Volatile cache PERC H700 (6Gb/s) with 512MB battery-backed cache SAS 6/iR PERC 6/i with 256MB battery-backed cache External: PERC H800 (6Gb/s) with 512MB Non-Volatile cache PERC H800 (6Gb/s) with 512MB of battery-backed cache PERC 6/E with 256MB or 512MB of battery-backed cache External HBAs (non-RAID): 6Gbps SAS HBA SAS 5/E HBA LSI2032 PCIe SCSI HBA Communications Optional add-in NICs: Dual Port 10GB Enhanced Intel Ethernet Server Adapter X520-DA2 (FcoE Ready for Future Enablement) Intel PRO/1000 PT Dual Port Server Adapter, Gigabit, Copper, PCI-E x4 Intel PRO/1000 VT Quad Port Server Adapter, Gigabit, Copper, PCI-E x4 Intel 10GBase-T Copper Single Port NIC, PCI-E x8 Intel Single Port Server Adapter, 10Gigabit, SR Optical, PCI-E x8 Broadcom® BMC57710 10Base-T Cooper Single Port NIC, PCI-E x8 Broadcom® BMC5709C IPV6 Gigabit Copper Dual Port NIC with TOE and iSCSI Offload, PCI-E x4 Broadcom® BMC5709C IPV6 Gigabit Copper Dual Port NIC with TOE, PCI-E x4 Broadcom® NetXtreme® II 57711 Dual Port Direct Attach 10Gb Ethernet PCI-Express Network Interface Card with TOE and iSCSI Offload Intel® Gigabit ET Dual Port Server Adapter Intel® Gigabit ET Quad Port Server Adapter Broadcom 10GbE NIC, Broadcom Dual Port 10GbE SFP+ Optional add in HBAs: Qlogic® QLE 2462 FC4 Dual Port 4 Gbps Fiber Channel HBA Qlogic® QLE 220 FC4 Single Port 4 Gbps Fiber Channel HBA Qlogic® QLE 2460 FC4 Single Port 4 Gbps Fiber Channel HBA Qlogic® QLE2562 FC8 Dual-channel HBA, PCI-E Gen 2 x4 Qlogic® QLE2560 FC8 Single-channel HBA, PCI-E Gen 2 x4 Emulex® LPe-1150 FC4 Single Port 4 Gbps Fiber Channel HBA, PCI-E x4 Emulex® LPe-11002 FC4 Dual Port 4 Gbps Fiber Channel HBA, PCI-E x4 Emulex® LPe-12000, FC8 Single Port 4 Gbps Fiber Channel HBA, PCI-E Gen 2 x4 Emulex® LPe-12002, FC8 Dual Port 4 Gbps Fiber Channel HBA, PCI-E Gen 2 x4 Power Supplies Two hot plug high efficient 502w PSU (Energy Smart) or Two hot-plug 717W PSUs (High Output) Uninterruptible Power supplies 1000W-5600W 2700W-5600W High Efficiency Online Extended Battery Module (EBM) Network Management Card Availability Hot-plug hard drives, hot-plug redundant power, redundant cooling, ECC memory, Single Device Data Correction (SDDC), supports memory demand, patrol scrubbing and high availability failover cluster Graphics Integrated Matrox G200, 8 MB shared video memory Chassis R610 Rack Height: 4.26cm (1.68”) Width: 48.24cm (18.99”) (includes rack latches) Depth: 77.2cm (30.39”) (includes PSU handles and bezel) Weight (maximum config): 17.69Kgs (39lbs) Management Dell OpenManage featuring Dell Management Console Lifecycle Controller iDRAC6 Enterprise (Optional) VFlash (Optional) Fans Standard redundant cooling Acoustics Typically configured6 2.5” chassis in 23 ± 2 C ambient Idle: LwA-UL7 = 5.3 bels, LpAm8 = 35 dBA Rack Support ReadyRailsTM sliding rails for 4-post Racks: Support tool-less installation in 19” EIA-310-E compliant square or unthreaded round hole 4-post racks including all Dell 42xx & 24xx racks NOTE: Threaded 4-post racks require the static ReadyRailsTM kit or 3rd party conversion kits available through Dell Software & Peripherals Support full extension of the system out of the rack to allow serviceability of key internal components Support optional cable management arm (CMA) except on Dell 4200 & 2400 racks and 3rd party racks that are less than 1m in depth Rail depth without the CMA: 798 mm (with outer CMA brackets attached), 768 mm (with outer CMA brackets removed) Rail depth with the CMA: 887 mm Square-hole rack adjustment range: 692-756 mm Round-hole rack adjustment range: 678-749 mm ReadyRailsTM static rails for 4-post & 2-post Racks: Support tool-less installation in 19” EIA-310-E compliant square or unthreaded round hole 4-post racks including all Dell 42xx & 24xx racks Support tooled installation in 19” EIA-310-E compliant threaded hole 4-post and 2-post racks Rail depth: 608 mm Square-hole rack adjustment range: 588-828 mm Round-hole rack adjustment range: 574-821 mm Threaded-hole rack adjustment range: 592-846 mm Regulatory and Environmental Compliance Regulatory Model: E01S Regulatory Type: E01S001
