Toshiba Qosmio G40-11D PQG40E-00500SGE (FTUSY6)
Discussion in 'BIOS/UEFI' started by prospa, Aug 23, 2016.
  1. prospa
    prospa Well-Known Member
    Hello need a bios dump for this laptop if it is possible , my laptop starts up but stuck at boot options menu , motherboard model FTUSY6 (A5A002189)
    Similar Threads - Toshiba Qosmio PQG40E Forum Date
    Toshiba Qosmio F60-12J BIOS/UEFI Feb 17, 2019
    Toshiba Qosmio F60 (PQF65A-065002) FLFSY2 A2814 BIOS/UEFI Feb 25, 2017
    Toshiba Qosmio G50-10H PQG55E FDUSY1 TOSHIBA Oct 29, 2016
    CẦN TÌM SCHEMATIC CỦA toshiba qosmio g30 Schematics Jul 28, 2016
    Toshiba Qosmio X300 - LA-4471P LS-4302P BIOS/UEFI May 24, 2016
  4. prospa
    i tested it allready , and i have exactly the same behaviour :/
    error what?
  6. prospa
    it powers on and stuck at boot option screen , i cannot boot from usb or hard disk or cdrom or enter the bios , i choose the boot option i want and then stucks , i press keys from keyboard and i hear a beep sound
    Not BIOS error, check hareware. :D
  8. prospa
    Yes, here is a file bios good, I've programmed it several times.
  10. prospa
    you are sure its ok with FTUSY6 motherboard? if yes then ill check hardware again ..
    Yes, sure
    Remove all the peripherals and test again.
  12. prospa
    i allready did this , ill check vga
  13. prospa
    it was bluetooth pci e card .... now everything ok :D thank you very much
