BIOS PC Z170-DELUXE
BIOS PC Z170-DELUXE 5 5 1votes
    Z170-DELUXE BIOS
    Z170-DELUXE-ASUS-1101 16MB
    5-Way Optimization: One click optimizes your entire system with a dedicated water-pump header on board
    ASUS Pro Clock Technology: Extends base clocks and improves stability for extreme overclocking
    6 USB 3.1 onboard: 5 Type-A ports and 1 reversible Type-C port
    Dual 32Gbit/s ultra-fast M.2 x4: Onboard and PCIe add-in card
    Hyper Kit: Bundled for instant U.2 support
    • CPU
      Intel® Socket 1151 for 6th Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
      Supports Intel® 14 nm CPU
      * The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
      * Refer to www.asus.com for CPU support list
    • Chipset
      Intel® Z170
    • Memory
      4 x DIMM, Max. 64GB, DDR4 3733(O.C.)/3600(O.C.)/3466(O.C.)/3400(O.C.)/3333(O.C.)/3300(O.C.)/3200(O.C.)/3000(O.C.)/2800(O.C.)/2666(O.C.)/2400(O.C.)/2133 MHz Non-ECC, Un-buffered Memory
      Dual Channel Memory Architecture
      Supports Intel® Extreme Memory Profile (XMP)
      * Hyper DIMM support is subject to the physical characteristics of individual CPUs.
      * Refer to www.asus.com for the Memory QVL (Qualified Vendors Lists).
    • Graphic
      Integrated Graphics Processor- Intel® HD Graphics support
      Multi-VGA output support : HDMI/DisplayPort ports
      - Supports HDMI with max. resolution 4096 x 2160 @ 24 Hz / 4096 x 2160 @ 60 Hz
      - Supports DisplayPort with max. resolution 4096 x 2304 @ 24 Hz / 4096 x 2304 @ 60 Hz
      Maximum shared memory of 512 MB
      Supports Intel® InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
      Supports up to 2 displays simultaneously
      DP 1.2 Multi-Stream Transport compliant, supports DP 1.2 monitor daisy chain up to 3 displays
    • Multi-GPU Support
      Supports NVIDIA® Quad-GPU SLI™ Technology
      Supports NVIDIA® 2-Way SLI™ Technology
      Supports AMD Quad-GPU CrossFireX™ Technology
      Supports AMD 3-Way CrossFireX™ Technology
    • Expansion Slots
      2 x PCIe 3.0/2.0 x16 (x16 or dual x8)
      1 x PCIe 3.0/2.0 x16 (max at x4 mode) *1
      4 x PCIe x1
    • Storage
      Intel® Z170 chipset :
      1 x SATA Express port, Compatible with 2 x SATA 6.0 Gb/s ports
      1 x M.2 x4 Socket 3, with M Key, type 2242/2260/2280/22110 storage devices support (both SATA & PCIE mode)*2
      6 x SATA 6Gb/s port(s), gray
      Support Raid 0, 1, 5, 10
      Intel® Rapid Storage Technology supports*3
      Supports Intel® Smart Response Technology*4
      ASMedia® SATA 6Gb/s controller : *5
      2 x SATA 6Gb/s port(s), black,
    • LAN
      Intel® I219V, 1 x Gigabit LAN Controller(s)
      Intel® I211-AT, 1 x Gigabit LAN
      Gigabit Intel® LAN Connection- 802.3az Energy Efficient Ethernet (EEE) appliance
      ASUS Turbo LAN Utility
      ASUS LAN Guard
    • Wireless Data Network
      Wi-Fi 802.11 a/b/g/n/ac
      Supports dual band frequency 2.4/5 GHz
      Support ASUS Wi-Fi Go! Utility
      Up to 1300Mbps transfer speed
    • Bluetooth
      Bluetooth V4.0
    • Audio
      Realtek® ALC1150 8-Channel High Definition Audio CODEC featuring Crystal Sound 3
      - Supports : Multi-streaming, Front Panel MIC Jack-retasking
      - High quality 112 dB SNR stereo playback output (Line-out at rear) and 104 dB SNR recording input (Line-in)
      Audio Feature :
      - DTS Connect
      - DTS Studio Sound
      - Optical S/PDIF out port(s) at back panel
      - BD Audio Layer Content Protection
      - Audio Shielding: Ensures precision analog/digital separation and greatly reduced multi-lateral interference
      - Dedicated audio PCB layers: Separate layers for left and right channels to guard the quality of the sensitive audio signals
      - Audio amplifier: Provides the highest-quality sound for headphone and speakers
      - Premium Japanese-made audio capacitors: Provide warm, natural and immersive sound with exceptional clarity and fidelity
      - Unique de-pop circuit: Reduces start-up popping noise to audio outputs
      - Top notch audio sensation delivers according to the audio configuration
      - Absolute Pitch 192khz/24bit true BD lossless sound
      Separate layer for left and right track, ensuring both sound deliver equal quality
    • USB Ports
      5 x USB 3.0/2.0 port(s) (1 at back panel, blue, Type-A, 4 at mid-board)
      5 x USB 2.0/1.1 port(s) (1 at back panel, black, Type-A, 4 at mid-board)
      ASMedia® USB 3.1 controller :
      5 x USB 3.1/3.0/2.0 port(s) (5 at back panel, teal blue, Type-A)
      1 x USB 3.1/3.0/2.0 port(s) (1 at back panel, , Type-C, Reversible)
    • Special Features
      OC Design - ASUS PRO Clock Technology
      - Full BCLK range for extreme overclocking performance
      5-Way Optimization by Dual Intelligent Processors 5
      - 5-Way Optimization tuning key perfectly consolidates TPU, EPU, DIGI+ Power Control, Fan Xpert 3, and Turbo App
      ASUS 5X Protection II :
      - ASUS LANGuard - 2.5X higher surge tolerance
      - ASUS Overvoltage Protection - World-class circuit-protecting power design
      - ASUS DIGI+ VRM - 16 Phase digital power design
      - ASUS DRAM Overcurrent Protection - Prevents damage from short circuits
      - ASUS Stainless-Steel Back I/O - 3X corrosion-resistance for greater durability
      ASUS TPU :
      - Auto Tuning
      - GPU Boost
      - TPU switch
      ASUS EPU :
      - EPU
      - EPU switch
      ASUS Digital Power Design :
      - Industry leading Digital 16 + 4 + 2 Phase Power Design
      ASUS Wi-Fi GO!
      - Wi-Fi GO! Function: Cloud GO!, Remote Desktop, Remote Keyboard & Mouse, File Transfer
      - Wi-Fi GO! & NFC Remote app for portable smartphone/tablet, supporting iOS 7 & Android 4.0 systems
      ASUS Exclusive Features :
      - GPU Boost
      - USB BIOS Flashback
      - MemOK!
      - AI Suite 3
      - Ai Charger
      - Ai Charger+
      - M.2 & SATA Express
      - Anti-Surge
      - Front Panel USB 3.0 Support
      - ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
      - USB 3.1 Boost
      - Disk Unlocker
      - Turbo LAN
      - Crystal Sound 3
      - EZ XMP ASUS Exclusive Features
      - Mobo Connect
      - PC Cleaner
      Remote Entertainment
      - Media Streamer
      - HyStream
      ASUS Quiet Thermal Solution :
      - Stylish Design Heat-pipe solution
      - ASUS Fan Xpert 3
      ASUS EZ DIY :
      - DirectKey
      - ASUS CrashFree BIOS 3
      - ASUS EZ Flash 3
      - ASUS USB BIOS Flashback
      - Multi-language BIOS
      - Push Notice
      ASUS Q-Design :
      - ASUS Q-Shield
      - ASUS Q-Code
      - ASUS Q-LED ()
      - ASUS Q-Slot
      - ASUS Q-DIMM
      - ASUS Q-Connector
      Special Memory O.C. Design
      Overclocking Protection :
      - ASUS C.P.R.(CPU Parameter Recall)
      Turbo App
      Fan Xpert 3
    • Operating System Support
      Windows® 10 , 64bit
      Windows® 8.1 , 64bit
      Windows® 7
    • Back I/O Ports
      1 x DisplayPort
      1 x HDMI
      2 x LAN (RJ45) port(s)
      5 x USB 3.1 (teal blue)Type-A
      1 x USB 3.1 Type-C
      1 x USB 3.0 (blue)
      1 x USB 2.0 (one port can be switched to USB BIOS Flashback)
      1 x Optical S/PDIF out
      1 x ASUS Wi-Fi GO! module (Wi-Fi 802.11 a/b/g/n/ac and Bluetooth v4.0/3.0+HS)
      1 x 8-channel Audio I/O
    • Internal I/O Ports
      1 x AAFP connector
      2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s)
      2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
      1 x SATA Express connector: ,
      1 x M.2 Socket 3 with M Key design, type 2242/2260/2280/22110 storage devices support (Supports both SATA & PCIE SSD)
      1 x TPM header
      6 x SATA 6Gb/s connector(s)
      1 x CPU Fan connector(s) (4 -pin)
      1 x CPU OPT Fan connector(s) (4 -pin)
      4 x Chassis Fan connector(s) (4 -pin)
      1 x S/PDIF out header(s)
      1 x Thunderbolt header(s)
      1 x 8-pin ATX 12V Power connector(s)
      1 x EZ XMP switch
      1 x System panel(s) (Q-Connector)
      1 x 5-pin EXT_FAN(Extension Fan) connector
      1 x DRCT header(s)
      1 x MemOK! button(s)
      1 x Thermal sensor connector(s)
      1 x TPU switch(es)
      1 x EPU switch(es)
      1 x Power-on button(s)
      1 x Reset button(s)
      1 x Clear CMOS button(s)
      1 x USB BIOS Flashback button(s)
      1 x Water Pump header (4-pin)
      1 x 14-1 pin TPM connector
    • Accessories
      User's manual
      ASUS Q-Shield
      6 x SATA 6Gb/s cable(s)
      1 x Feature manual
      2 x M.2 Screw Package
      1 x CPU installation tool
      1 x Supporting DVD
      1 x ASUS 3T3R dual band Wi-Fi moving antennas (Wi-Fi 802.11a/b/g/n/ac compliant)
      1 x HYPERM.2 X4 with M Key design, type 2230/2242/2260/2280/22110 storage devices support (Support PCIE SSD only)
      1 x SLI bridge(s)
      1 x Q-connector(s) (1 in 1)
      1 x ASUS Hyper Kit
    • BIOS
      128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0, ACPI 5.0, Multi-language BIOS, ASUS EZ Flash 3, CrashFree BIOS 3, F11 EZ Tuning Wizard, F6 Qfan Control, F3 My Favorites, Quick Note, Last Modified log, F12 PrintScreen and ASUS DRAM SPD (Serial Presence Detect) memory information
    • Manageability
      WfM 2.0, DMI 3.0, WOL by PME, PXE
    • Form Factor
      ATX Form Factor
      12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
    • Note
      *1: The PCIe x16_3 slot shares bandwidth with SATA6G_56. The PCIe x16_3 is default set at x2 mode.
      Supports Intel® RST for PCIE RAID storage.
      *2: The M.2 socket shares SATA ports with SATA Express. Adjust BIOS settings to use an M.2 SATA device.
      *3: Supports PCIE RAID configurations via onboard M.2 and PCIEX16_3 slot storages.
      *4: These functions will work depending on the CPU installed.
      *5: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
    Similar Threads - Z170 DELUXE Forum Date
    BIOS PC Z170-DELUXE BIOS/UEFI Aug 24, 2015
    BIOS PC 111-SS-E172 - EVGA Z170 Stingger 11-SS-E172-KR LGA-1151 DDR4 BIOS/UEFI Sep 22, 2018
    BIOS PC 140-SS-E177 - EVGA Z170 FTW, 140-SS-E177-KR LGA-1151 DDR4140-SS-E177 - EVGA Z170 FTW, 140-SS-E177-KR BIOS/UEFI Sep 22, 2018
    BIOS PC 151-SS-E179 EVGA Z170 Classfied 4 Way... BIOS/UEFI Sep 22, 2018
    BIOS PC EVGA Z170 Classified K 142-SS-E178-KR BIOS/UEFI Sep 22, 2018
