IBM-Lenovo g40-30 nm-a311
Discussion in 'BIOS/UEFI' started by technical, Apr 27, 2015.
IBM-Lenovo g40-30 nm-a311 4.5 5 2votes
4.5/5, 2 votes
  1. tankhanglaptop
    tankhanglaptop Well-Known Member
    model name: 80fy
    s/n: pf02z1fs
    MTM:80fy006gvn
    mo: pf9xb 4819042
    factory id: jvhfc1
    bios cũ đây a ơi giúp em với ạ
    g40-30 cpu n2840.rar
    G40-30 Laptop (Lenovo)
  3. msnessy247
    msnessy247 Well-Known Member
  4. 11ifix
    11ifix Moderator
    your NM-A311 clear me bios is working fine but please fix invalid serial no in bios
  5. 11ifix
    11ifix Moderator
    Please fix invalid serial no in clear me bios
    need not fix need Programming one bios other, bios old error what ?
  7. 02ifix
    02ifix Well-Known Member
    g50-30 ? is the same EC bios as g40 ? , SIO was damaged , installed new one and flashed it with the version you got here , but machine turn on but no SUSP# commands from SIO . if no susp# no 3vs or 5vs and therefore plenty o other voltage wont come on. let me know if EC file is same for G50-30 board same version nm-311 rev 1.0
    Only same motherboar code.
  9. 02ifix
    so the EC you got in this thread wont work ?
    what you mean ? your english is strange mate :p
    Just tell me what you need ? :p
  11. 02ifix
    i was asking if the EC file you got for the g40-30 works ok on a g50-30 ? because with this EC file i can't run SUSP# commands
    Programming ok, Please check tool Programming....
  13. 02ifix
    i use vertyanov programmer , and until now i didnt had any troubles flashing SIO's , MEC ITE ENE SMSC nuvoton , and the flash works 100% write and sucessful
    so if you say the EC dump of the g40-30 is the same as g50-30 , then must have something wrong somewere .
  14. Lalit Kumar sachdeva
    Lalit Kumar sachdeva Well-Known Member
    Lenovo G50-30 80G0_a7cn48ww NM-A311
    A7CN48WW
    BIOS Notification:
    Fixed
    1. Follow LNV PCR to fix UEFI vulnerability LEN-2015-049:Configuration Bypass During S3 Resume.
    2. Fix UEFI vulnerability LEN-2015-084:MemoryConfig variable does not been locked correctly.
    EC Notification:
    Modified
    1. Save storage mode flag to EC ROM in order to fix storage mode lost when shutdown without AC power.
    • Like Like x 2
  15. refixya
    refixya Well-Known Member
    nm-a311 hd images is available plz send
  17. komtumi
    komtumi Well-Known Member
    I have same problem. Change PU401 fix problem. Dump is OK
  18. mshtaq
    mshtaq Well-Known Member
    hi
    please clear me for this dump G50-30 ?
    thanks
    clear me G50-30.bin
  20. mshtaq
    Thanks a lot
Similar Threads - a311 Forum Date
LIFEBOOK A3110 BIOS BIOS/UEFI Jul 9, 2017
IBM-Lenovo G40-30 - ACLU9/ACLUO NM-A311 Schematics Oct 8, 2015
FUJISTU Fujitsu Siemens Livebook A3110 C1CP302570-X2 Schematics Oct 22, 2014
FUJISTU FALCON_C1CP302570-X2 VB313AA Fujitsu Lifebook A3110 Schematics Oct 4, 2014
IBM-Lenovo Lenovo 3000 N100 LA3101 LA3111P Schematics Apr 30, 2014
