HP EliteBook 840 G3 - 6050A2728501-MB-A01
Discussion in 'BIOS/UEFI' started by technical, Jul 2, 2016.
HP EliteBook 840 G3 - 6050A2728501-MB-A01 5 5 1votes
  2. VANTOM
    VANTOM New Member
    led is blinking 5 times on boot monitor not working
    clear me and no clear same problem. Please check hardware. And please find out what Me Region.
  4. VANTOM
    VANTOM New Member
    when i flash my 16mb file than boot the notebook, when i flash your file then i became led 5 times
    your file is only 8mb
    File Clear me i send is file old you send me, i only help clear me, sure 16MB ( you need to extract the zip before Programming) Understand ?
  6. VANTOM
    VANTOM New Member
    ok i had unzipped before i flash
    #46 VANTOM, Oct 13, 2017
    after unzip size 8MB or 16MB ?
  8. VANTOM
    VANTOM New Member
    16mb. Was my error. But i write the bin in the Archiv. Dont work. Blinking 5 times. This notebook has 2 bios chips. The another one is 8 mb
    Why abive you say bios i send 8MB ? Please downloads bios above top and Programming.
    If it's the same problem you need to check and repair the hardware....
  10. 03ifix
    HOW TO PROGRAM BIOS REMOVE THE BACK COVER AND SEE BIOS CHIP? IF YES YOU TRY PULLING OUT THE MOTHERBOARD REMOVE ALL THING AND CHECK THIS SAME PROBLEM I FACE MANY TIME.WHEN I PULLING OUT BOARD PROBLEM SOLVE TRY MAYBE SOME HELP.
  11. joselifer
    joselifer New Member
    Can I extract the bin file from the bios without programmer?
  12. joselifer
    which of the two chips is the password?
  13. 03ifix
    THE BIOS PASSWORD STORE IS 16MB BIOS.ONLY USE PROGRAMMER TO SAVE 16MB BIOS.
  14. bushmann
    bushmann Well-Known Member
    Dear all.
    Please can you help me with clear password from this BIOS file.
    Thanks .
    Unlock
  16. godzzila
    godzzila New Member
    Please unlock password, THX
    840 G3_Unlock.bin
  18. godzzila
    godzzila New Member
    Unfortunately I got bad dump probably and its not working.. :( I tried another UNI ME unlock BIOS and it gaves black screen.. can you verify this unlocked dump?
  20. QuocKhanhLaptop
    QuocKhanhLaptop Well-Known Member
Similar Threads - EliteBook 6050A2728501 Forum Date
hp elitebook 840 g5 BIOS/UEFI Feb 3, 2021
HP EliteBook 745 G6 BIOS/UEFI Aug 1, 2019
HP EliteBook 755 G5 TRYPTICO 6050A2945701-MB-A01 (A1) BIOS/UEFI Aug 1, 2019
HP EliteBook 1050 G1 BIOS BIOS/UEFI Jun 28, 2019
HP EliteBook x360 1040 G6 BIOS BIOS/UEFI Jun 28, 2019
